Results 1 to 3 of 3
    Sep 2015
    Default BMW Bosch ME9.2 Virgin
    Hi folks,
    I have Bosch ME9.2 from E87 116i that failed during update at dealer. Car cannot start. Over BDM I could read eeprom and Micro, but flash cannot be read, it throws cheksum error. As I couldnt find same number flash file, I found BDM read from same car, N45 116i engine, manual transmision. If I compare Micro files from mine original and from other ecu I see there are also diferences in files, mine ori has much less data containing, is it possible that it was damaged during flash also?
    Now I have few questions.
    -ISN and VIN are stored in flash also, can this flash be virginised?
    -mine eeprom seems original so does it also need to be virginised if flash is virginised?
    -can you check if my original micro is also damaged?
    Here I post both files, Micro and eeprom from mine failed one and full BMD read from another ecu. Original ecu numbers are 0 261 209 036 and I used BDM for flash from 0 261 209 085. Now on BDM VIN is detected from that flash and old one is gone.
    https://files.fm/u/u9kg7xp4
    https://files.fm/u/2djssj22
    Sep 2015
    Bump No one can make virgin this ECU?
    Fec001's Avatar
    Read CAS and upload dump to synch with "new" DME dump
