Results 1 to 7 of 7
    DK Veteran konatist's Avatar
    Nov 2008
    The Toon
    Default Duo 2 boot problem
    Have a vu duo 2 had flashed with open atv now its stuck on the atv boot logo and wont go past, ive tried reflashing with various sticks but no joy is it time to part ways with old trusty
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Try flashing back to an earlier image
  3. The Following User Says Thank You to cunny For This Useful Post:
    konatist (20th July, 2017)
    Nov 2008
    The Toon
    Cheers cunny lad tried reflashing a few times ill try a older image tomorrow
    Nov 2008
    The Toon
    Worked problem seems to be the centre lcd is not showing any info i flashed as i picked a usb up that has a led so it was flashing so i knew it was re flashing the box. And its working but no main centre lcd any thoughts
    cunny's Avatar
    Jan 2009
    The Shoutbox
    The image your using could be wrong. Could be missing Ltd display drivers
    DK Veteran lincsat's Avatar
    Jun 2008
    Try flashing the stock OpenViX image without doing a settings restore and see if that works. It definitely has the drivers for a genuine Duo2.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Or could easily display itself or connection
