Try this:
Mazda 6 gs1d 57k30 ori 08 Borrisnossary_clear.rar
Cosmetic differences
Can someone clear U3000 from these dumps light stays flashing.
Car had voltage problem and we clear with carprog
1 is ori dump
2 is clear via carprog
Thanks.
Mazda 6.rar
Swiftec - Ecu Decoder - Winols - Carprog - FGTECH - Kess - Ktag - VVDI - PP2000 - Lexia - Vagcom - Vauxcom - Odis Ori - Autocom Ori - And lots of friends who I help and they help me
Please give thanks if I helped.
Try this:
If I helped, please click button "thanks".
It does not cost you anything.
No this solution not work
Looks to me like it is hardware issue or file corrupt.
🔥Wacka Wacka 🔥
Ok guys thanks anyway
hello, im new here, i also need that file, can you please tell me how to download it?
swirl (10th March, 2018)
Same problem with same unit and U3000 dtc,can someone help me ?
Hello , i thought u solved the problem in your previous thread, says tht atmel chip caused the problem, anyway i attached clear file , it might helps you, because its tested.
95640 CLEAR.rar
Don’t bite off more than you can chew...Don’t bite the hand that feeds you...
chiorbeq (16th September, 2019)
Pinout connection to verify on bench for this unit?
