Results 1 to 3 of 3
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default bmw e46 2.0 popcorn
    hi friends
    need
    popcorn on bmw e46
    the oxygen and mod is on it already
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    any help??
    May 2017
    will sent you later .
    Edit: Here it is.
    you dont need to kill dtcs for after cat lambda delete... you can set lambda automatic detection .
    Put ecu inside, disconnect lambda, clear adaptions and it will search in can bus for parts by himself .
    Also didnt think your tune based on logging... m54 didnt need changes in ign tables where you made .
    So there are more potential tune for b22 possible. (over-lap, disa...) .
  4. The Following User Says Thank You to Lambda1 For This Useful Post:
    robert1232 (26th July, 2019)
