Results 1 to 11 of 11
    Mar 2013
    PT
    Default CD30 MP3 + TID - How to unpair dump?
    Hi friends,
    I have a relative that has problems on it's Astra H Estate, pairing a BID with a CD30 MP3, originally it had CD30 but he somehow deactivated theft protection and it cannot be activated thru OPCOM, for reasons unknown to me.
    I was able to dump the ROMs of both devices, but I haven't managed to virginize it, as I don't know the offsets on the ROM responsible for holding this info.
    Can anybody please help me on this?
    I'm posting here the links to the files:
    https://mega.nz/#!9wQhlY5B!nqLRtwRrR5H8Vvn5cBdlmlYAljFwRHfAx5x0l41lspI BID
    https://mega.nz/#!tlZUBSpS!93k3oqX4rLC8iTL14fuxrK9cIkYlS58_uYlHa84vH8A CD30MP3
    bank's Avatar
    Feb 2017
    Ukraine
    cd30 mp3 - carpass is 3768
    bank's Avatar
    Feb 2017
    Ukraine
    BID - carpass is 7278
    bank's Avatar
    Feb 2017
    Ukraine
    If you have something virginized, you can virginize these devices/
    If you have virginized cd30, you can pair it with bid using 7278, then unpair with the same carpass.
    Then connect paired cd30mp3 with virginized BID and unpair cd30mp3 using 3768
  5. The Following User Says Thank You to bank For This Useful Post:
    tycoonlink (21st July, 2017)
    Mar 2013
    PT
    Quote Originally Posted by bank View Post
    OPCOM doesn't seem to be able to deactivate the theft protection using these codes. So, my guess is that I manually have to edit the dump.
    But what needs to be modified in the dump in order to be virginized?
    bank's Avatar
    Feb 2017
    Ukraine
    I don't think so.
    I did described solution with OpCom china clone and with GM MDI many times. One paired device with one unpaired could be paired and unpaired.
    It's possible for you also if you have one item of unpaired display or EHU
  8. The Following User Says Thank You to bank For This Useful Post:
    tycoonlink (20th July, 2017)
  9. #7
    Mar 2013
    PT
    I don't think so.
    I'll give it a try tonight. Thanks.
  10. #8
    bank's Avatar
    Feb 2017
    Ukraine
    Just say which of devices you have in delivery state
  11. #9
    WALES
    Quote Originally Posted by tycoonlink View Post
    Hi friends,
    Use this dump and pair with 7278
    wbr
  12. The Following 3 Users Say Thank You to shooting For This Useful Post:
    ilen (21st July, 2017), irfa (21st July, 2017), tycoonlink (20th July, 2017)
  13. #10
    Mar 2013
    PT
    Quote Originally Posted by shooting View Post
    wbr
    Worked perfectly! Thanks.
    I see you changed a byte (0x3E8 - 0x3EF). What does it means?
  14. #11
    bank's Avatar
    Feb 2017
    Ukraine
    It puts EHU in delivery state
  15. The Following User Says Thank You to bank For This Useful Post:
