I am about to install later sti clocks in my 03wrx, I have a 93c56 eprom on the 03wrx clocks, have read that with ponyprog and a SI adaptor, however the sti clocks have a l56r small soic 8 chip, I have an adaptor but should the same programmer work to read and write to this chip. Also does it have to be removed or can it be read with a clip on board, any help appreciated. the sti clocks are from a 2006 sti. I have calculated the codes I need and know which lines to change, just need a little advice as it will be the first time I have attempted this, the larger chip on wrx dash came off easily, but I am a litte concerned at the prospect of removing the smaller one, but if it needs to come off I know someone who can do this for me, just need a little info on the programming of it.
