Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 71
  1. #16
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    yes put to locked position and than try ignition on. Yes i mean resolder every on pcb.
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  2. #17
    I tried in lock position: when I insert key it unlock and in diagnose I have error in kessy about defective ELV.
    If I erase error car will start, but if I remove key I have the same error and I need to erase it again to start car.
    I resolded every component on pcb and no-luck
  3. #18
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    I think motor in lock need open and cleanup comutator (this is where brushes coming) motor have small torgue. you have two elv? try change mechanic part from donor elv
  4. The Following 2 Users Say Thank You to Pyromaniak For This Useful Post:
    soxten (11th August, 2017), yugo45 (11th August, 2017)
  5. #19
    The problem was not mechanical part of ELV.
    I use the original motor and original mechanical part, but swap original MCU on new pcb board and problem solved!
    I think problem was in hall sensor for close position, when elv close it make some noise and motor not stop...
    Mates thank you for any help
    Bests
  6. The Following 4 Users Say Thank You to paskuale For This Useful Post:
    clauberty (25th April, 2020), jamesclegg (15th April, 2021), Pyromaniak (12th August, 2017), yugo45 (11th November, 2017)
  7. #20
    Nov 2017
    Quote Originally Posted by paskuale View Post
    Bests
    I am having the same problem on the cayenne. Did you transplant your MCU to a used unit or a brand new unit?
  8. #21
    I soldered my MCU on another good used unit with same part number.
    bests
  9. The Following User Says Thank You to paskuale For This Useful Post:
    yugo45 (12th November, 2017)
  10. #22
    Nov 2017
    Ordered a used steering lock from Ebay (had to find hard for one that is younger than mine ) Did the exact same thing. Transplanted the MCU from my original board to the replacement one. Used the replacement as a whole. Now the cayenne is no longer a paperweight.
    I strongly believe the part that failed on mine was one of them hall sensors. One gave weird resistance readings compared to the other 2. They (all 3) were the same sensors.
    Thanks for the pointers
  11. #23
    Member Audi SP's Avatar
    Oct 2011
    Word
    hI,
    I have the exact same problem..
    so if I buy used elv I can solve?
  12. #24
    Yes, you will solve with another working ELV.
  13. #25
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    its only problem of motor i replace many time only motor and job is done . remove motor and put there china motor elv will work like new .
  14. The Following User Says Thank You to lashkar97 For This Useful Post:
    doctore (3rd January, 2018)
  15. #26
    Not always is motor issue.
    I repaired two VW Touareg and never motor was fault.
    You can test motor with 12V
  16. The Following 2 Users Say Thank You to paskuale For This Useful Post:
    lashkar97 (3rd January, 2018), yunchuli (30th July, 2018)
  17. #27
    Jul 2018
    I have the same problem on my Phaeton 2012, is the MCU the one marked with 72334/MTN...?
    Where did you get the good used unit? Is it difficult to swap the MCU?
    Anyone tried placing relays (tyco v23086-c1001-x008) instead? I search it in google and found a few results mentioning the same problem: https://www.yoycart.com/Product/532789339630/
  18. #28
    You can start by change relays, they are a common fault on this unit.
    In my two cases I had problem on other component, maybe motor position sensor.
    But always I swap MCU on another good ELV and solve the problem.
    It’s not much difficult if you have good soldering skills.
    I found they in scrappy.
    Good Luck!
  19. The Following User Says Thank You to paskuale For This Useful Post:
  20. #29
    Jul 2018
    Good Luck!
    Thanks for replying, paskuale. I would like to purchase a good ELV but I don't know what's "scrappy" as I lived in Taiwan. I will try Taobao or ebay instead. Do you know what's the MCU model in 4E0905852E ? Just a backup solution if I ruin the original MCU...
    How do you disassemble 4E0905852E? Any special tool required? I have it in hand but not sure how to disassemble it...
  21. #30
    Hello my friend!
    Scrappy is scrap yard, where you find broken cars to sell working parts
    If no scrappy in Taiwan you must use eBay or something like this.
    You can’t read the MCU in this ELV, so you must swap it from broken ELV to working ELV. Don’t try to read, you can erase it and then only dealer can help you with new entire steering barrel because ELV is not sold lonely as spare part.
    To disassemble it no need any special tool, only you have to unscrew the two security screw on it. You make a slit and then unscrew with flat screwdriver.
  22. The Following User Says Thank You to paskuale For This Useful Post:
