Ista D is ideal, but it's hardly a 10 second process. You do it your way. I'll do it mine.
ive done many e60 cas2 no issues, more than i can remember. only 2 times crank no start and needed resync. 1 vehicle is because power died from bad battery customer did not tell me battery dies after few minutes, and 2nd time i did add key and got error, i usually never do add key and always just generate and works good, so maybe that caused.
both times fixed by disconnected battery both + and - and let sit for 20 minutes, reconnected battery and used ista/d to resync. car starts right up after sync.
Can anyone shed light on how to use ISTA D to do a Synch, after battery reset? It will be helpful in future, if anyone has Step by Step
Clear dme/dde fault codes
Disconnect battery.
Wait 20 mins. Count it. Don't be impatient.
Reconnect battery.
Ideally, connect battery support unit.
Check no fault codes. Do not try to start car.
Do cas/ews to dme/dde resynch.
Ista D - service functions. Just follow the instructions.
hi members
have little problem .with cas 2 when add dealer key with remote or key .
new key change on e60 km to miles and today remote on e91 change language french to german just with this added Key ori key no problem .
Envoyé de mon SM-A605FN en utilisant Tapatalk
Is there steps when you program new key cas 1-3..
I watch you tube channel how to (with cgdi because I have cgdi) and don't see exactly steps how to do it...for example: first read keys save eeprom then make dealer key in this step do i need to check box of unused place for key or no... after that(making dealer key) can I start car or need add key first...thanks for help
Ews 3
External 12v needed for producing key or not!? Today I tryed producing key after loaded bin file which i read with xprog, always error when try producing key.
CAS3 - PART NUMBER 9147225 today could not read key data
security data failed several times, finally went through but error could not read key data and then obd timeout.
completed with another tool
Tools owned -
I make car with xprog,and i have ak90...but i have also cgdi bmw and i need to know.
