We said it several times, thy say it works only on F series not E series models like E70, E90 and so on..
Hi, Droidwayne65, thanks for you suggestion. we will put forward to engineer.
droidwayne65 (3rd August, 2019)
Hello everyone, i am looking to buy CGDI BMW but I see in the comments this toll is not safe and the car can't start after make a new key.
Can you tell me please in the new updates this problem is fixed or no?
From what I must to be careful and what bugs have this tool at the moment.
Today i did a 6hp egs on a f02 7series, however, it does not have the function to virginize it. What i did was back up the data from the original module an write it to the used module already installed in the car. I'm wondering... would it be possible to get a dump from a virgin unit in case the original module is not available?
hesham10 (22nd January, 2021)
UPDATE CGDI Prog BMW V2.9.0 (2019.09.09) NEW
Adds B48 B58 OBD read ISN
Add French version
Modify F series VO coding
Add search button to E series hidden function
add OBD repairs original car data
add OBD replaces car removal module
older updates in case you didnt see them
CG-DI V2.8.0
(2019.07.20)
1. Added Spanish version
2. BMW EGS Change: increase EGS_6HP
3. Fix E series programming E89, R56 car English version display problem; Increase the detection of foot space on programming CAS
4. Optimize BMW diagnostics, E system code interface
CG-DI V2.6.0
(2019.03.05)
1. Added: EWS1-3 key matching function.
2. The E-code is modified to modify the VO code function, and the VO code can be added or deleted directly by the selection method, and the operation is simpler.
3. The BMW data modification adds support for both N13 and N55 engine data.
CG-DI V2.5.0
(2019.01.10)
1. Added BMW E series programming, support single module programming of E60, E65, E70, E89, R56 and other chassis models (multimedia module requires fiber optic communication, temporarily not supported).
2. Added BMW E series code, support E60, E65, E70, E89, R56 and other chassis models single module code, backup code and recovery code.
3. FEM/BDC key matching: Add 0000155E.018_120_010, 00002419.081_010_020 two versions of FEM/BDC with key.
4. F/G system programming: increase the support of swfk, flup, blup programming files, and fix some programming failures.
5. CAS1-CAS3+ key matching: increase the Rolls-Royce CAS1, CAS2 key matching.
6. BMW data modification: Add CAS3+, CAS4+ ISN encryption and decryption functions.
7. Maserati Mileage Adjustment: Added the function of saving EEPROM data.
8. BMW F-series codding:Fix List display incomplete.
jamesfawcett (14th November, 2019), rojhat (10th September, 2019)
Hello, any review on b48, 58 ISN reading? Thank you
cgdi bmw cant program e90 dme online.
Hi guys please i am thinking of buying this tool for cloning bmw ecu like msd80, msd81, msv80.
Can do clone this ecus this tool ?
Many thanks in advance.
spiridonas (17th November, 2019)
please all i need isn for bmw X5 cas3 , i have cas eeprom and flash dump
they tell me that he reads and writes
r7f701401 / 402
they tried
Today i have mini BMW clubmann 2008year and cgdi f.. up
After read key, Mark key5 ,make dealer key, add key...car start...but ,when car is closed/open car not start...try sync.elv but nothing....fixed with fvdi 2018...what I am doing wrong!????
Nothing :> Sometimes things like that like to happen when dealing with CAS via OBD and that's why I always eeproming them. Same issues happens with vvdi2 also.
Wouldn't be a problem unless sync with vvdi2 would be possible but not always work and FVDI work7, thats amazing hehe
hitechservis (29th November, 2019)
