Oh dear , go sleep, ok?
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
good for you
A little strange, don't you think? Maybe tell us what did you do during that 4 month period with this tool and then say what happened recently. Because now your opinion does not look serious.
Yes we don't know nothing from your posts now, so please elaborate.
Ok,first I don't sell any tool,so my reply is only to help.I tested in 2 Minicooper 2013 both,one was all keys lost Cas3+ and the other one it was just add key,in both situation Cgdi works flawlessly,downgrade the cas in around 8 minutes,then,in all keys lost I inserted the key around 10 times to finally the process,in the add key situation,just put the key in the Cgdi antenna and that was all.So until now I wanna say Cgdi works in Cas 3+.
Greetings From Mexico.
p1et (29th March, 2018)
Just downgrade cas and Cgdi ask insert key until 64 times,1 by 1,so,if the just crank insert the key in Cgdi,and reinsert again in car's slot,and again,and again same step until the car stars.
Well that method with 64 max start attempts should work WITHOUT downgrading CAS I think? The theory of downgrading CAS is to be able to program key straight in without DME dump / known ISN right? So when you downgrade, then you should be able to program new key straight by OBD. Or now I AM missing something?
As I understand, you downgrade CAS so that you can read/write to it over OBD. In all keys lost situation you still need the ISN, so the 64 attempts is trying to guess the ISN ?
It Is correct.
CGDI PROG bmw f20 2014 mileage reset OK
yugo45 (3rd March, 2018)
Hi friends.
First car, not work. Z4 E89 cas3+
Best regards
