2011 E90 320i Cas3 + IstaP.
Downgrade and add dealer key by OBD successful.
Try key up to 64 times (38th time lucky)
Brat (10th May, 2018)
Did key programming with bmw f36 2015 fem, works fine only could not save coding. I had programmed key car did not start, fixed coding with bmw tool. Before programming it say that coding could not be stored for back up. I have done 2 mini 2014 and 2015(BDC) , 1 F30 Fem 2013 and 1 f36 fem 2015. Al cars work fine only coding back up off f36 fem i had to fix with bmw tool.
I've had it four days. I've done three jobs with it. One successful. Two failures.
Another failure today!
9389115. CAS3+ - with existing key this time "Version not supported."
That's four jobs I've taken this to and only one has worked. Why does 9389115 not work even with a good key?
I'm thinking this was a waste of money.
It word good on f series
Well, two more successes to add to the list.
2010 Mini Cooper Cas3+ Add key. Downgraded, key added, ISN read from existing key. Unsuccessful. ISN obtained by trying to start car <64 times. Successful.
2006 E90 Cas 3 Add key. Successful.
today i write a mini cooper key with fem module and cas4+ all succes and cas 2 on obd and again succes !! its a good tool and i am very satisfyed !!!
I tried CAS 3+ ISTAP today and it was successful, downgrading took around 5 minutes, and then programmed key successfuly
p1et (8th June, 2018)
Updated CGDI BMW released yesterday apparently.
I haven't seen nor installed it, yet.
PixelsFixed (12th June, 2018)
Hi.
I have programmed the FEM module and then it does not accept a key and it does not accept the renewal to program new keys, as I must proceed to activate this module, it does not accept any operation.
