Brat (29th August, 2018)
Not possible to read this ecu in boot mode,i will try soon with this tool cgdi bmw
i try in table write/chenge isn in med17 but not success!
doctore (8th September, 2018)
CGDI Prog BMW key programmer newly added BMW CAS1, CAS2, CAS3, CAS3+, CAS3++ odometer correction function via OBD
Hi, please check your OBD connections, maybe it not connect successfully.
teerak2uk (12th September, 2018)
teerak2uk (16th September, 2018)
what do you guys use to make CAS4 keys? i know cant be done OBD, i have cgdi, 100% successfull cas1-3+ but never tried cas4, any recommendations on programmers? i tried acdp and did not work, maybe defective item, but returned to seller.
CG Pro 9S12
vvdi prog
Some version of R270.
doctore (23rd September, 2018)
Finally ran into a problem with it, twice. Both cars E90 with MSV80 ecus. It reads a 16-byte ISN from the ecu but when I attempt to read the CAS ISN, it gives a "version unsupported" error. I read the CAS on the bench and they're both CAS3, 0L01Y with a two-byte ISN.
Can you post eprom cas and isn from ecu to see
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
droidwayne65 (23rd September, 2018)
LMAO!! Thank you, @doctore, for you interest. After I posted that ISN pic, I wondered if it was the correct one for that CAS. Just for the hell of it, I searched the CAS eeprom for the different strings and, lo and behold, the 16-byte string is indeed stored, just not at 0x0748~. It's at 0x0BBC~ in plaintext, so I now know how to do the match. I think I previously searched for the wrong string . I love this place; was just browsing, saw this thread and decided to post my issue. Along you come, expressing interest, spurring me to check further and voila ! Thank you, sir!
This is the correct pic:
