does this tool read and write isn as it say or not
wiseman (10th December, 2018)
This is an insane app, LOL! Had to install a donor ecm in a 2008 X5 and it said the CAS needed to be downgraded in order to read the ISN. All went perfect until I tried to write the new ISN to the CAS, when up popped the "Unsupported Version" error. So, once again, I had to remove the CAS and manually edit the data. Crazeee, LOL!
Hello firiends ,
I am a newbie in the adding key bussiness. I am looking to buy this CGDI BMW Tool.
Can you please tell me , is ok this tool for E90 , E60 card and normal key ?
Is safe to use it with CAS3 and CAS3+ to add key with an exisiting working key on the car ?
And if i can add for example on BMW F10 key.
Thank you all.
Yes. It'll do all of that.
I've no experience of VVDI2. I've never had any problems with the "safety" of CGDI.
p1et (7th January, 2019)
Saved me some time with a ME9.2.2. Cloning with K-tag resulted in two bricks, so I got another, read the ISN in a couple seconds and manually edited the CAS. Much faster than reading the flash with Kess.
can this device extract ISN from f-series N20 ecu without cutting open for boot pin?
unclear from following video if the boot pin is connected
https://www.youtube.com/watch?v=JMfZw1xFssI
been using this tool for over a year and have never had any issues making keys, ive used this successfully to downgrade cas, read dme ISN, e90 e60 F10 CAS4, all lost keys, even works good on bench setup.
here is video on using cgdi bench to make key.
here is video on reading DME ISN msv80 with cgdi
I prefer to directly read ISN from DME, because ive had a few freezes reading via OBD2.
doctore (23rd January, 2019)
