doctore (24th September, 2018)
now its good i dont look in cas 2
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
droidwayne65 (24th September, 2018)
Tried it on CAS 2 key programming, success.
Tried it on CAS3 key programming by obd2, success
Tried it on CAS3+ with ista-p, downgraded and programmed key, success.
who has tried to read ISN from EGS?
you can not read only reset
"6.Support BMW Key unlock"
What exactly is the key unlock function?
For example, does it take used keys from other vehicles and clear the transponder so it can be used with another vehicle - i.e. make them "virgin"?
Is this referring instead to the ability to pull the encryption key(s)?
Or does remove keys from the CAS slots?
Or some other function?
Whatever the function may be, is it also confirmed working?
You certainly can't "virginise" used keys.
All I've been able to do with it is clear a key I've already programmed. I made two keys for a guy who never came back, I loaded up his key info and unlocked them and put them back into stock.
Or I did one yesterday where it programmed the key on position ten, but didn't work. I unlocked it, put it on position five and it was fine.
camparks (2nd October, 2018)
doctore (3rd October, 2018)
Start
Fail
Reprogram key
Start
Fail
Reprogram key
Start
Fail
Reprogram key
You can get a bit of a rhythm going.
doctore (4th October, 2018)
Have patience. Took them three weeks to authorise it for me and another ten days for mileage adjustment.
