Page 26 of 35 FirstFirst ... 162122232425262728293031 ... LastLast
Results 376 to 390 of 523
  1. #376
    We said it several times, thy say it works only on F series not E series models like E70, E90 and so on..
  2. #377
    Aug 2018
    Hi, Droidwayne65, thanks for you suggestion. we will put forward to engineer.
  3. The Following User Says Thank You to LISA100 For This Useful Post:
    droidwayne65 (3rd August, 2019)
  4. #378
    Aug 2018
    Quote Originally Posted by jaberheraz View Post
    Does it support bmw E70 gearbox 6HP26Z
    Dear, For 6HP , just support F series.
  5. #379
    Apr 2019
    Hello everyone, i am looking to buy CGDI BMW but I see in the comments this toll is not safe and the car can't start after make a new key.
    Can you tell me please in the new updates this problem is fixed or no?
    From what I must to be careful and what bugs have this tool at the moment.
  6. #380
    Jun 2010
    Today i did a 6hp egs on a f02 7series, however, it does not have the function to virginize it. What i did was back up the data from the original module an write it to the used module already installed in the car. I'm wondering... would it be possible to get a dump from a virgin unit in case the original module is not available?
  7. The Following User Says Thank You to joguzman For This Useful Post:
    hesham10 (22nd January, 2021)
  8. #381
    Jan 2017
    USA ����
    UPDATE CGDI Prog BMW V2.9.0 (2019.09.09) NEW
    Adds B48 B58 OBD read ISN
    Add French version
    Modify F series VO coding
    Add search button to E series hidden function
    add OBD repairs original car data
    add OBD replaces car removal module
    older updates in case you didnt see them
    CG-DI V2.8.0
    (2019.07.20)
    1. Added Spanish version
    2. BMW EGS Change: increase EGS_6HP
    3. Fix E series programming E89, R56 car English version display problem; Increase the detection of foot space on programming CAS
    4. Optimize BMW diagnostics, E system code interface
    CG-DI V2.6.0
    (2019.03.05)
    1. Added: EWS1-3 key matching function.
    2. The E-code is modified to modify the VO code function, and the VO code can be added or deleted directly by the selection method, and the operation is simpler.
    3. The BMW data modification adds support for both N13 and N55 engine data.
    CG-DI V2.5.0
    (2019.01.10)
    1. Added BMW E series programming, support single module programming of E60, E65, E70, E89, R56 and other chassis models (multimedia module requires fiber optic communication, temporarily not supported).
    2. Added BMW E series code, support E60, E65, E70, E89, R56 and other chassis models single module code, backup code and recovery code.
    3. FEM/BDC key matching: Add 0000155E.018_120_010, 00002419.081_010_020 two versions of FEM/BDC with key.
    4. F/G system programming: increase the support of swfk, flup, blup programming files, and fix some programming failures.
    5. CAS1-CAS3+ key matching: increase the Rolls-Royce CAS1, CAS2 key matching.
    6. BMW data modification: Add CAS3+, CAS4+ ISN encryption and decryption functions.
    7. Maserati Mileage Adjustment: Added the function of saving EEPROM data.
    8. BMW F-series codding:Fix List display incomplete.
    The thanks button is HERE looks like this --->>> THANKS
  9. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    jamesfawcett (14th November, 2019), rojhat (10th September, 2019)
  10. #382
    Top Poster rojhat's Avatar
    Sep 2015
    france
    Quote Originally Posted by sleepyrz View Post
    Add French version
    CG-DI V2.8.0
    (2019.07.20)
    CG-DI V2.6.0
    (2019.03.05)
    CG-DI V2.5.0
    (2019.01.10)
    Hi possible share. Auto updater dont find new update
    Envoyé de mon SM-A705FN en utilisant Tapatalk
  11. #383
    Dec 2015
    LITHUANIA
    Hello, any review on b48, 58 ISN reading? Thank you
  12. #384
    Sep 2014
    cgdi bmw cant program e90 dme online.
  13. #385
    spiridonas's Avatar
    Hi guys please i am thinking of buying this tool for cloning bmw ecu like msd80, msd81, msv80.
    Can do clone this ecus this tool ?
    Many thanks in advance.
  14. #386
    Apr 2016
    Quote Originally Posted by spiridonas View Post
    no...........
  15. The Following User Says Thank You to K1nd3r For This Useful Post:
    spiridonas (17th November, 2019)
  16. #387
    Default bmw x5 cas3 + isn
    please all i need isn for bmw X5 cas3 , i have cas eeprom and flash dump
  17. #388
    Apr 2010
    they tell me that he reads and writes
    r7f701401 / 402
    they tried
  18. #389
    Mar 2017
    Today i have mini BMW clubmann 2008year and cgdi f.. up
    After read key, Mark key5 ,make dealer key, add key...car start...but ,when car is closed/open car not start...try sync.elv but nothing....fixed with fvdi 2018...what I am doing wrong!????
  19. #390
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by hitechservis View Post
    Nothing :> Sometimes things like that like to happen when dealing with CAS via OBD and that's why I always eeproming them. Same issues happens with vvdi2 also.
    Wouldn't be a problem unless sync with vvdi2 would be possible but not always work and FVDI work7, thats amazing hehe
  20. The Following User Says Thank You to p1et For This Useful Post:
    hitechservis (29th November, 2019)
