Results 1 to 9 of 9
    Dec 2010
    Default AUDI A4 2.0 TDI PPD1.3 DPF OFF 03G906018AQ
    Hello friends,
    I need help with dpf-off for Audi A4 2007 2.0 tdi, 03G906018AQ, PPD1.3
    File read by BDM
  2. The Following User Says Thank You to xdamdamx For This Useful Post:
    Art1703 (12th March, 2023)
  3. #2
    Nov 2015
    Lublin/poland
    Quote Originally Posted by xdamdamx View Post
    Hello friends,
    File read by BDM
    try this
    press thanx and rep
    test and report
  4. The Following 5 Users Say Thank You to kostrz3 For This Useful Post:
    Adi202 (16th October, 2023), enoman21 (19th March, 2021), jurlak1 (8th May, 2023), mirec87 (8th January, 2024), ProblemChild (13th October, 2021)
  5. #3
    Dec 2010
    DTC ok, but still DPF on dashboard
  6. #4
    Aug 2012
    file is ok reset dpf and make regeneration drive from dpf than light is off
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Nov 2015
    Lublin/poland
    carbon mass must reset (vcds)
  8. #6
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    reset dpf by vcds or delphi.
    i always forgot to do this before flashing , then i have same problem like you
    but don't worry, it's disappear.
    DSG TUNING
    File Service
  9. #7
    Mar 2018
    Romania
    Please help me!! I need dpf-off for Audi A4 2.0 tdi, 03G906018AQ, PPD1.3.
    I did DPF off with DPF Remover but don't work , does not accelerate more than 2800 rpm and i get an error P2563 turbocharger Boost control position sensor circuit . Thanks in advance , please help me!! I have attached both files.
  10. #8
    Mar 2018
    Romania
    I'm sorry , This is my original file .
  11. #9
    Jun 2021
    Quote Originally Posted by kostrz3 View Post
    try this
    press thanx and rep
    test and report
    thanks i will try the file
