sensor disconected?
For the great ecu connoisseur.
Egr and Fap were shut down and a few dtc switched off. After 10-15 days, ecu goes to safe mode.
Dtc P0473 (dtc off) the difference in the pressure of the exhaust gases, if one knows how to shut down the gas pressure sensor, I would be very grateful.
I use mpps v13 and pp2000
PUG 307 HDI.rar
sensor disconected?
ivicajanko (22nd November, 2017)
I tried everything out of error P0473 and the car goes to safe mode. While the car ride is not going to the safe mode only when I turn on the car I throw it in a safe mode, after 10-15 days of driving. Try to solve the problem if you can.
Best regards
try this matte
Last edited by diabollic; 28th July, 2017 at 03:02 PM. Reason: Do not forget to thank
ivicajanko (30th July, 2017)
kostrz3 dtc is already off . thanks
diabollic
The car works for now ok . Test and report. Thanks
sensor disconected but the car still goes to safe mode. thanks
You have problem with something, try to remove egr and fap without delete dtc. . If you cant find solution for egr dtc, just connect another egr and test.. i mean you have problem with turbo pressure, or some defect sensor.. dtc for egr cant goes car to safe mode.. where are you from?
Sent from my SM-G955F using Tapatalk
ivicajanko (26th October, 2017)
Prokuplje Srbija
try this one
disconnect diff. pressure sensor
deleteing a DTC does absolutely nothing on engine functionality if there is a problem to cause LIMP it will limp!
Thanks johak . Test and report
