Results 1 to 5 of 5
    Aug 2008
    Default Eurovox ex5000pvr.
    Hi All.
    I'm hopefully getting the Eurovox ex5000pvr with hard drive on Monday.When I do get it will I have to download the firmware file 1.1A or 1.1 version to flash the box,or both?Probably been asked before but I can't help but ask.Also when I have flashed the box I then connect my cable and scan for channels is this correct?
    Thanx in advance Wheezystorm.
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    It's always best to flash the latest firmware as this will have the latest fixes and features. So I would go for 1.1a.
    Aug 2008
    Default Thanx
    Quote Originally Posted by Devilfish View Post
    Thanx for the reply devilfish,when your new to all this you get a bit wary in case you damage the box. cheers.
    Jun 2008
    use a null modem to flash the v1.1a and then it goes into scan mode after its loded firmware..sometimes you have to be a bit patient as it goes through its steps. It will ask you to ok scan after searching for transponders.
    DK Veteran lincsat's Avatar
    Jun 2008
    Depends where you get it from, some suppliers do pre-load the latest firmware and test the boxes prior to dispatch - or maybe that's just me
