milerk (27th September, 2013)
try this files dont forget cut pin 20 immo line ecu
ahlan houya youssefi, i have try the file and cut the pin 20, the car start only for the first time, but after dont work , thank's khouya, i put off the eeprom, dont have another choice
you have kango dti 1.5
hello, no i have an 1.9 dti, do you have a solution please?
YOU MUST USE IMO KILER END RENO EMULATOR FOR THIS COMP
remove this chut 25080 or 95080 and all is ok no immo
tested and ok 100/100
hello, i did it, i remove the eeprom but as you know, when we do this the car stop hotting at start "le prechauffage ne marche plus"
ok i try to clear immo original dump
you van try this
Try this!! Good luck!
must use emulator
hi everybody, i?ve got the solution for this ECU. Only need to burn a pic, make a small circuit and reprog the 95080. If anyone want to try it here it is. If you have any experience with pics this will be really easy, otherwhise ask and i?ll post the wiring schematics
i need schematics please
thx
hello, thank's all for answering, please we need shematic for Olecram solution, thank's and good luck for all
