Results 1 to 13 of 13
    Ireland
    Default Audi A6 2008 Dealer key programming
    Does anyone know what are the options for programming a new dealer key to a 2008 Audi A6. This is a spare key, we have a working key.
    I have the pin code from the engine ECU. The ecu accepts the pin code but I cannot log in to the Kessy with vcds.
    Sent from my ONEPLUS A3003 using Tapatalk
    Apr 2011
    Maybe car has immo off?
    check vin numbers in ecu and kessy.
    Ireland
    No, the car is definitely standard. Everything is original.
    When I try Security access in Kessy it says Controller refused to send seed. Error 22 Sequence Error
    yugo45's Avatar
    You can not do this car with VCDS.
    Need to have advance tool, VVDI , AVDI can do it .
    Ireland
    Okay thanks
    Jan 2016
    You need to have 6 bytes CS and PIN to make dealer key and learn it. Made A6 05 today all key lost.
    Dec 2012
    EU
    Quote Originally Posted by amigokola View Post
    He has new dealer key
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    yugo45's Avatar
    Key form dealer comes programmed with CS.
    BTW, check you PM , i send you one. Maybe you did not see it because Forum acting strange , you have to refresh page when you go to Pm, to be able to see new one.
  9. The Following User Says Thank You to yugo45 For This Useful Post:
    amigokola (5th August, 2017)
  10. #9
    Jan 2017
    Where do you guys get virgin flip keys for these?
  11. #10
    rob h's Avatar
    May 2011
    Google 4F0837220 R
    You will need 868mhz.
    Or get something like this: RKE audi A6L Q7 3 button remote chip 8E 2005-2010 (google)
  12. #11
    Jan 2017
    Quote Originally Posted by rob h View Post
    Google 4F0837220 R
    Ive heard about 8e chips, i am in us market, i believe they are 433mhz. Can you virginize a used one or remove the used transponder and put in an 8E?
  13. #12
    rob h's Avatar
    May 2011
    The emergency key holds a glass 8e transponder.
    The flipkeys have a electronic chip, inbedded in the circuit.
    The remote will work as soon you program this key.
    Make sure you have the correct part number!
  14. #13
    rob h's Avatar
    May 2011
    A used remote key can be reset, if you have the ezs dump file with it.
    A 8E is only for emergency start.
    There is no 8e in a remote key!
    Only the aftermarket Chinese remote kits work that way.
  15. The Following User Says Thank You to rob h For This Useful Post:
    yugo45 (6th August, 2017)
