Hi.
Give this one a try
Regards,
Hi.
Give this one a try
Regards,
imddman (3rd August, 2017)
100% working manual solution
You can unplug the sensor
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
Will any of these maps increase power? Or it's that impossible with these engine?
I ain't a killer but don't push me Revenge is like the sweetest joy next to gettin pussy ...
Friend i tell you Its impossible, Its N/A engine... u Can increse your power after exhaust, manifold... but Its big costs and not a lot of power... better is sold this car and buy turbo engine
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
imddman (4th August, 2017)
For more power in AQN you should do good CAI (TB diameter is same as 204HP 2.8 24V, so it's enough), modify exhaust installing metal CAT and one back box, pipe diameter not more than 60mm
This will give you not more than 10hp
Mapping this engine and any other VR is a pain because you need really good fuel, if not ignition retard kicks in and all is gone.
Of course spark plugs and coils must be in perfect shape and compression test is a must!
As you can see this is lots of $$$ for just litle gain.
