Results 1 to 7 of 7
    May 2011
    Ireland
    Default Fiat Ulysse 2.2 hdi dpf off
    hi all,
    i need DPF off Fiat ulysse 2.2 hdi
    75vG.
    0281011522103737
    1037370785B075WF
    75WF
    2S01C87B000287__NZGG
    BOSH 0281011522
    Top Poster TWINGO's Avatar
    ITALY
    Quote Originally Posted by czaderx View Post
    hi all,
    75vG.
    0281011522103737
    1037370785B075WF
    75WF
    BOSH 0281011522
    You can use ECUSAFE. Process the file with
    Citroen driver. After remap remove dpf in body
    With diagnosis device. Your ecu is edc15c2.
    (please, press thanks button)
  3. The Following User Says Thank You to TWINGO For This Useful Post:
    czaderx (9th August, 2017)
    Hi Your dpf off.
    Pass PM.
    Tell me how did you read BDM?
  5. The Following User Says Thank You to bodzio012 For This Useful Post:
  6. #4
    May 2011
    Ireland
    thanks just created name cos i have bit mess in laptop. ecu read by obd2. thanks anyway. just to be clear: do i need to instal "new" fap by lexia or just write data and is done?
    May 2011
    Ireland
    Hi car is not starting with this map.
    Quote Originally Posted by bodzio012 View Post
    Hi Your dpf off.
    Pass PM.
  8. #6
    If write mpps, there is checksum. If not there is checksum.
  9. The Following User Says Thank You to bodzio012 For This Useful Post:
    czaderx (18th August, 2017)
  10. #7
    May 2011
    Ireland
    pass please
