Results 1 to 7 of 7
    Default mercedes w202 c220cdi edc15c0 hot start maps help
    Hi to all i need a hand here, i´m having a problem with a w202 c220 cdi and i hope someone can help me with it
    i´m having a hard time finding the cold / hot start maps in this ecu can someone help me with this please
    i need to change start from 60º onwards
    heres the file
    Fec001's Avatar
    Start map - 0C10E
  3. The Following User Says Thank You to Fec001 For This Useful Post:
    tellfaia (10th August, 2017)
    Not working yet already changed and no luck can someone help me with this please
    Fec001's Avatar
    I think you have mechanical problem. Check Rail pressure and leaking at injectors
  6. The Following User Says Thank You to Fec001 For This Useful Post:
    tellfaia (11th August, 2017)
    injectors, pump, and fuel pressure regulator changed
    what i need its something like its done in the vag group like hotstart fix and i´m pretty sure it will be perfect because when we disconnect the temp sensor the car works perfect
  8. #6
    PierreTheron's Avatar
    Centurion,South Africa
    So if coolant temp disconnected it goes to default map .. Is valves not setted correct?
  9. #7
    crank map anyone knows?
