Results 1 to 8 of 8
    Jul 2015
    Default Pin Code Vw Passat 2006
    I need pin code for passat 2006.
    I send eprom from confort module 95320.
    doctore's Avatar
    Nov 2015
    Colorado Denver
    tr pin code -38359
    immo vwzcz0000000000
    vin wvwzzz3cz7p100980
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Jul 2015
    the pin not work
    doctore's Avatar
    Nov 2015
    Colorado Denver
    i think is correct post eprom from ecu
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  6. The Following User Says Thank You to kiszka For This Useful Post:
    doctore (11th August, 2017)
    Mar 2017
    KISZKA is wirte the pin and cs from KISZKA is ok.
    kiszka's Avatar
    Reality of life :
    4:Everyone lies
  9. The Following User Says Thank You to kiszka For This Useful Post:
    ZAHEER (12th August, 2017)
  10. #8
    Mar 2017
    THE HELP IS FOR OTHER WHO POSTED I AM JUST RECOMENDING YOUR POST IS CORRECT FOR PIN AND CS
    BUT I WILL STILL THANK TO YOU
