Results 1 to 4 of 4
Thread: Iveco Daily
    Autotecno2006's Avatar
    Default Iveco Daily
    Hi all, Iveco Daily 2009 3.o hpi Fault code 28b , Can someone tell me what is the P code for this ? Need to Delete it !
    Thanks P
    Default iveco Daily 3.0 hpi
    can Someone Remove Flap from 2009 Iveco Daily 3.0 hpi, Thanks
    Regards P
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Manufactured dtc 28B its not related to swirl flaps !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Ok, Edc light flashing, examined flap & seems to be ok, goes on & off as normal. this only info i have, any advise ? Regards P
    The code 28B = short circuit to battery (+) at throttle valve actuator. In case of permanent fault, the TVA solenoid valve is set to rest position (normal open). If the ignition is on the TVA flap should close until you start the engine. You can see this by removing the hose coming from the intercooler.
    Check the condition of the TVA connector and valve operation, replace the valve if is in short circuit.
    The code 188 is generated by the first defect.
    TVA connector pins configuration.
    1. PWM signal - 2. Positive - 3. Earth - 4. Throttle position signal.
