    Dec 2016
    Default OPEL CORSA D 2010 1.2 AIRBAG Eeprom problem
    Hi!
    I do have an Airbag Module from Opel Corsa D Temic 13 283 819 and want to remove crash data.
    The car has an accident at front but the Airbags hadn't blow up. Despite this when I connect the auto to diagnostic tool some airbag fault come out.
    When I open the module and unsolder the EEprom 95160 I cannot read it ;/ ;/ ;/
    The Carprog in Airbag module shows:
    [12:07:19] Reading chip...
    {!} ID not found
    when i go to read/write it shows only:
    00 00 00 00 00
    I tried also to read it with USB-UPA. In USB-UPA if i check connections, everything is green and OK, but USB-UPA also read this EEprom and shows:
    00 00 00 00 00
    1. Any advice how to repair it?
    2. Is the Eeprom or dump broken?
    3. Probbalby You have any oryginal dump without crash data to write on it?
    4. Should I write on new EEprom or use this?
    Thank in advance
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    you trying to read with an adaptor clip?
    solder to a board and it will read
  3. The Following User Says Thank You to whiskeyman For This Useful Post:
    kubuswujo (12th August, 2017)
    Dec 2016
    When I try read with Carprog I use clip, but unsoldered from Airbag module.
    When i try to use with USB-UPA then I solder it into adapter for 95xxx series.
    while using USB-UPA it shows Veryfy status OK and thats starange... Which Voltage should I use? 3V or 5V?
    Dec 2016
    have already readed the EEprom can someone look if its ok and clear crash data?
    whiskeyman's Avatar
    Dec 2010
    HERE YE GO TRY AND TEST
  7. The Following 3 Users Say Thank You to whiskeyman For This Useful Post:
    dimo (24th April, 2019), kubuswujo (15th August, 2017), VIMA46 (11th April, 2019)
  8. #6
    Oct 2018
    Milano Italy
    Thanks for your file without password
