bugarcek (12th August, 2017)
Can someone turn limp mode off in this ecu... car is going in to limp mode, if just turn key to off and on it goes normally until it throws it in limp mode...
I changed turbo sensor, maf turbo refulator, checked hoses... car goes like a hell when it is not in limp mode... there is no fault in ecu... I thinked that it is egr but is not... Can someone turn limp mode off or tell me how to do this?
Thansk
maajkii (13th August, 2017)
You have a problem in geometry of the turbocharger
Need cleaning
click here---->Vw tdi turbocharger vnt
good luck
tell me thanks I will be very happy
kostrz3 (13th August, 2017)
DSG TUNING
File Service
There is no any fault... with stock file also... I removed egr because I just think that fault is there... with ori file same problem and no dtc... It is very funny because car went super today morning without any limp mode... but now again throws in limp mode
Check your n75 valve, and underpressure leaks. Maybe there is a problem, Its not safety to turn off Limp mode...
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
