sonic 1989 (15th August, 2017)
Hello
I have read ecu from my 530d E60 2005 for tunnig and a have error C0207 and C000A
can somone remove DPF and disable this errors (C0207 and C000A) and make tunning
I found C errors are chasis errors and will check ABS sensors tomorow on Delphi i can`t see error on ABS so i will check maual with multimeter (old school)
So I need ecu remap, dpf off, and if possible disable this errors for coming maybe alignment off
Sent from my E6853 using Tapatalk
car is stock? dpf drilled?
here's your stg1 + dpf off
pass pm
DSG TUNING
File Service
I mess up with flash now ecu need bdm I I think eeprom are erased to. Any instructions how to do to get it work again?
NEVER USE MPPS ON EDC16C35
Never use mpps on all ecus... better buy China galletto clone...
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
U need to flash full bdm now... I try to find full bdm read for you.. just give me your all ecu info..
DSG TUNING
File Service
nikte (16th August, 2017)
Full bdm will help me and save time as soon I get bdm flasher interface xprog
and things looks like this after read with bdm looks like missing part on address where i read before with mpps and i have that backup, i try to make file and if someone can check this
i attach file that i read with mpps (partial read) , bdm (full read after things go wrong with mpps) and possible fix where i add missing part from 1 read with mpps differences start at 000C0000
Find virgin epprom. Flash it and car should start.
DSG TUNING
File Service
my original eeprom seeams to be ok i`m just not sure about flash maybe should be check with winols for checksum ?
i will try to start later today car and programmer are 50km far away
I can't take a look, but my flash is 100% ok with chks of course... just don't use mpps to flash it
DSG TUNING
File Service
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
Car started and I will like to thanks you all guys for participating and helping also thanks to one member off this forum for hardware support (I don't know his name) :-)
DSG TUNING
File Service
