Results 1 to 5 of 5
    norman1967's Avatar
    Dec 2015
    Amsterdam
    Default Zgemma box what's the best one to buy?
    Hello all
    Looking for advice on the best model zgemma I should buy right now off eBay?
    Did consider the mag 254 for iptv however from what I can tell I can get the zgemma to work with iptv/virgin and sly so seems likes a better but for more options??
    Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
    4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
    digicon's Avatar
    Jul 2009
    Zgemma H.3TC
  3. The Following User Says Thank You to digicon For This Useful Post:
    norman1967 (21st August, 2017)
    DK Veteran lincsat's Avatar
    Jun 2008
    Do you mean the H3.2TC? There is also the H5.2TC with H265 video playback support
  5. The Following User Says Thank You to lincsat For This Useful Post:
  6. #4
    norman1967's Avatar
    Dec 2015
    Amsterdam
    Hello lads
    Was going to buy ebay
    272750934360
    But now seen 272769832512
    what are diffrences all I can see is one allows you to record at the same time another two channels which to be honest I will never need to do.
  7. #5
    digicon's Avatar
    Jul 2009
    Zgemma H.2H = Single DVB-S2 satellite Tuner + Single DVB-C/T/T2 Cable/FreeviewHD Tuner
    Zgemma H3.2TC = Single DVB-S2 satellite Tuner + Dual (2) DVB-C/T/T2 Cable/FreeviewHD Tuner
  8. The Following User Says Thank You to digicon For This Useful Post:
    norman1967 (23rd August, 2017)
