Results 1 to 7 of 7
    Feb 2017
    Default Toyota Aqua/Prius C Cluster Removal Help!!
    I removed the cluster successfully and now it seems i have to raise the glass lcd screen off the cluster to remove the screws to open it.
    But this screen is glass and seems like it wants to crack very easily, how can i remove this cluster lcd without damage?
    plz help i don't want to damage
    Feb 2017
    This is what i have done so far (See image)
    Feb 2017
    never mind, got thru using plastic tool at the side to pry up gently, for anyone else info its small chip next to Fujitsu MCU
    Feb 2017
    here is toyota aqua 2013 93c66 msop dump 90xxxkm , in case anyone needs it
  5. The Following 2 Users Say Thank You to daxt0r For This Useful Post:
    Johnner (18th August, 2017), Valeri (18th August, 2017)
    Jul 2017
    Assume Japanese? I have Prius C English
    Feb 2017
    yes the dump is from a japanese toyota aqua i'm not sure if it will interchange with us toyota prius city although its save vehicle
  8. The Following User Says Thank You to daxt0r For This Useful Post:
    Valeri (27th August, 2017)
  9. #7
    Oct 2020
    SRILANKA
    Quote Originally Posted by Valeri View Post
    hi. you have a dump file prius c English
