Results 1 to 5 of 5
    Usa
    Default VW CADDY 1.6 TD PCR2.1
    hi
    i need good dump egr off dpf REMOVE DTC P046C + P 0408
    vw caddy 1.6 pcr 2.1 ecu :03l907425c engine CAYD
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by quikcar View Post
    hi
    you will have problems with dpf after you remove these codes , not this week or next week but soon after will start regen all the time and over fill oil level
  3. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    maajkii (18th August, 2017)
    Usa
    thx mate
    but i need solution for this car
    engine without power
    i need remove egr & fap from ecu and exhaust
    Mar 2008
    birmingham
    acs dpf 2017 software works 100% on this ecu
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default your file
    your file. Press thanks and rep buttons pass pm
