Results 1 to 7 of 7
Threaded View
    Dec 2016
    Default Peugeot 308 1.6 HDI "Risk of particle filter blocking fault"
    Hi i do have a problem with Peugeot 308 1.6 HDi 92 KM 2010 i have made a Stage 1 Chiptunning on 110KM an do atached an oryginal and moded file.
    But the customer says that when he do accelerate than the message on dash shows up:
    what is bad made in the Map ?? I have made a cleaning of DPF throught OBDII software but the problem comes back after a three days.
    The customer is not willing to remove the DPF. What can be done better in program? I have started since may and still been learning....
    Can someone edit it a good way probably with lower Power but without fault.??
    Thanks in advance!
