Results 1 to 8 of 8
    dariobmw's Avatar
    near THE NORTH FACE
    Default error P1442 from C5 2.0HDI
    Good morning this is a file from a C5 2.0 hdi , kan someone delete P1442 error from this file
    THANKS ALOT !
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    FAP is still there, or not...?
  3. The Following User Says Thank You to bobolin4o For This Useful Post:
    pike (27th August, 2017)
    dariobmw's Avatar
    near THE NORTH FACE
    Thanks for iterest mate the fap is no more there
    bobolin4o's Avatar
    This file, from the first post, is original, or is FAP off?
    dariobmw's Avatar
    near THE NORTH FACE
    As told from the howner of the car the file is off and some tune ..... the car is here only for the P1442 problem , never see this ecu before
    bobolin4o's Avatar
    Test this...
    Regards!
  8. The Following 3 Users Say Thank You to bobolin4o For This Useful Post:
    dariobmw (24th August, 2017), drewdom (26th August, 2017), pike (27th August, 2017)
  9. #7
    dariobmw's Avatar
    near THE NORTH FACE
    Good i try and report ....... the file extension extasiant ".BOB" :-)
  10. #8
    dariobmw's Avatar
    near THE NORTH FACE
    Perfekt the problem is solved !!!!!!!!!
  11. The Following User Says Thank You to dariobmw For This Useful Post:
    bobolin4o (26th August, 2017)
