Hi..
You mod file
Hi..
You mod file
tehnosoftex (24th August, 2017)
Hi, this file is made with ads and I already test it, don't work. I need tested solution.
DSG TUNING
File Service
Are you sure that you use swiftec on this one? This is 100% volta solution with mass murder dtc. All dtc are off. I did test on the car a combination of ads and volta but no joy.
its swiftec, maybe its same solution, idk i dont use volta.
DSG TUNING
File Service
If not working other try my solution
chipdanix (24th August, 2017)
Hi, I don't know what swiftec did you have friends but not one of these solutions is swiftec. I ask a friend which had swiftech and he make me a good dpf off without all dtc off like in this solutions and with other maps changed. Now the car runs ok and no error message except c301 which is common at these cars.
lsdlsd88 (25th August, 2017)
