Results 1 to 9 of 9
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Default Rover 825 1997 year automatic MKC 103991 need location eeprom and immo off
    Hi All, Rover 825 1997 year automatic MKC 103991 need location eeprom and immo off, maybe somebody help me with this. This 93c66 Atmel read for immo off ?
    Thanks in advance.
    BR
    Dragon
    Scripts for Multi-PROG
    Best regards.
    Dragon
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    i think yes in uid is like MEMS 3 this ecu
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  3. The Following User Says Thank You to Pyromaniak For This Useful Post:
    dragon100 (25th August, 2017)
    dragon100's Avatar
    Jan 2012
    For this ecu not work UID, I have problem with starter, immo off I have ok, but I need solution for starter, because it is automatic. ???
    Best regards.
    Dragon
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    if in engine bay are six relays, one is for starter.
    dragon100's Avatar
    Jan 2012
    yes mate, but need good solution, I know which relay for starter, but need start car only if gear in P position no in D :-) somebody said 10 pin cut from alarm module and join to ground and starter work good but in this Rover not work , then I still wait for good solution , thanks in advance ...
    Best regards.
    Dragon
    dragon100's Avatar
    Jan 2012
    Problem solved. First, open ecu and find eeprom 93c66, read as 8bit, change file, write immo off, cut pin 17 from black connector ecu before connect ecu, then cut wire Black/White from central locking unit and join to the ground, cut wire Violet/Black to the horn, car starts ok.
    Thanks for RomanDon and "The Car Doctor".
    Best regards.
    Dragon
  8. The Following 3 Users Say Thank You to dragon100 For This Useful Post:
    ilDandi (9th August, 2019), Pyromaniak (14th July, 2018), RomanDon (29th August, 2017)
  9. #7
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    do you mean purple / back wire ? dosnt looks black/white
  10. #8
    dragon100's Avatar
    Jan 2012
    Purple/black Violet/black for horn, black/white only one in this unit ...You know, men's knows only 3 colors, black, white and ...When I will join central locking with remote I will do better photos ...
    Best regards.
    Dragon
  11. #9
    dragon100's Avatar
    Jan 2012
    Hi, for central locking need join for 2 pair wires, orange and pink, 1 pair for driver's door lock motor and 2 pair for rest of door's lock motor, use direction connect, no impuls + or -. If central locking unit is damage, need also cut violet/red (purple/red) wire from central locking unit and join to the +12V, then work switch open for trunk and fuel filler ...
    Best regards.
    Dragon
  12. The Following User Says Thank You to dragon100 For This Useful Post:
    konop11138 (18th December, 2017)
