Results 1 to 8 of 8
    Nov 2016
    Leeds UK
    Default Vauxhall ASTRA H 2005 problem with remote
    I have a problem with remote in my Astra '05
    All keys was lost so i bought the new one. Blade already cuted and immo programed.
    Now I have a problem with remote. It's already add to car but to make it works I need to disconnect battery. After I put it to ignition its stop working - next battery disconnection - working again.
    Any idea whats is wrong?
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by rafik71 View Post
    Your battery is dead. Try another battery. Don't messure the voltage, just change it
    Nov 2016
    Leeds UK
    Battery on remote is ok - changed twice.
    To make it work I need to disconnect car battery not this one in remote.
    Remote is allright coz when I have connected Diagun I can see on some data read that remote buttons are working
    Jan 2016
    The plunger in end of ignition barrel is not returning when removing key from ignition. Are you getting boing noise and radio staying on? Remove ignition barrel, strip & clean out all the crap thats accumulate. Make sure the spring now freely returns plunger back to position when key is removed. Refit and will now work.
  5. The Following User Says Thank You to Cr4nky For This Useful Post:
    Duracell2 (26th August, 2017)
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Is this chinese key or ori key?
    Nov 2016
    Leeds UK
    I'm not sure but I think that is original one.
    I'll check that wey with non returning
    I think it can be problem with this because my radio is staying on when I take out the key.
    Duracell2's Avatar
    Apr 2017
    I'll check that wey with non returning I think it can be problem with this because my radio is staying on when I take out the key.
    there you go
    Nov 2016
    Leeds UK
    Problem solved. I've cleaned my igniotion lock and now is working fine
