i cant see this dtc inside file.
ALL TUNING.
THE BEST OR NOTHING. THANKS + REPUTATION .
The table DTC not present in this ecu?
Of course it present, but i think your file was read through OBD...
For sure, in this partial file, there are config switches for CAT, SAI, etc... but without a DAMOS it's mission impossible...
Regards!
CoeraPejo (28th August, 2017)
Hi, this is complete Read.
Possible remove DTC P0420?
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
CoeraPejo (5th September, 2017)
I have damos for this car, but dtc remove is not enought.
Recode with NSCExpert not possible also.
@daynight- wrong mate.There is no damos file for this car , ECU is Siemens EMS2000.
DTC can be made off , i assure you, made this job on over ten files.Also can be recoded with NCS Expert,first gen.of R50 Mini Cooper from 2001 don't have second lambda.
Trimis de pe al meu SM-G935F folosind Tapatalk
bobolin4o (6th September, 2017)
Car Mini Cooper R50, VIN nr. WMWRC31070TH43963, car produced 2004-07-06, first owner Italian,Chili Red colour,gearbox Getrag,and so on.
Here you are your sw with DTC P420 made off.Test and report.
CoeraPejo (7th September, 2017)
You havent. I have full damos 100% I make decat with switches.
hi
I would like to kindly ask to disable DTC P0420
thanks in advance
Here you are ,nice space blue metallic car.
meli (27th March, 2019)
Hi guys, please help me with dtc off P0420 in my mini siemens ems2, thanks in advance
