Results 1 to 7 of 7
Thread: W963 NEC key
Hybrid View
    auto techniek's Avatar
    Mar 2017
    Default W963 NEC key
    Hi M8
    I have a key from a client . The key start the car but does not open the doors. Car W639 from 2005
    Battery are ok. Doors close and open with the dashboard switch.
    No light when you press the buttons.
    Where do I have to look? Any ideas what the problem?
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by auto techniek View Post
    Hi M8
    W963 ? what thats for model ??? have some screen ?
    have some remote tester ? check signal of each remote function
    many thanks to friend kevfield
    Mar 2017
    Sorry W639
    Signal tested. Nothing happens
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Sorry W639
    check with diag when car see remote signal from key, maybe receive antena broken
    or check EZS, maybe bad MCU series on pcb...like 4J74Y
  5. The Following User Says Thank You to daxxer For This Useful Post:
    auto techniek (29th August, 2017)
  6. #5
    lion0304's Avatar
    Oct 2014
    If no light on key when pressing button, that mean you need repair PCB board and change all switch to be sure.
    No need diagnosic for that.
    This is the first thing you need to do.
  7. The Following User Says Thank You to lion0304 For This Useful Post:
    auto techniek (30th August, 2017)
  8. #6
    Mar 2017
    Nec chip swapped to a donor key that I ve and problem solved.
    I wil check later if I can save the old PCB.
    Quote Originally Posted by lion0304 View Post
  9. #7
    unu's Avatar
    Oct 2010
    EUROPE
    maybe was water inside pcb ...
