Results 1 to 7 of 7
    nickolasd's Avatar
    Nov 2015
    Default 2005 sprinter EGR delete
    05 sprinter with 2.7L om647 engine EDC16C2 read over obd with kess
    i need EGR delete with egr connector staying in place.
    thank you.
    huskypt's Avatar
    Apr 2016
    PT
    Hi.
    Try this
    nickolasd's Avatar
    Nov 2015
    pass please
    nickolasd's Avatar
    Nov 2015
    somebody else please help. can't use file from huskypt.
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Here is your file with EGR deactivated.
    No checksum calculated, let the tool to make it.
    Regards!
  6. The Following 3 Users Say Thank You to bobolin4o For This Useful Post:
    nickolasd (6th September, 2017), pike (6th September, 2017), tech020 (10th July, 2019)
    nickolasd's Avatar
    Nov 2015
    i have a little problem, sprinter with bad egr goes into limp mode with this file. if i install good working used egr from another vehicle everything is good drives fine and egr stays closed.
    bobolin4o's Avatar
    Of course, in this file the EGR is only closed, not deleted...
    This was your request in the first post.
    Deleting the EGR from the file completely is definitely more work...
    Such job, i (and anyone, i assume...) will not do for free.
    Because of the Forum rules, which i respect... i think, that i have nothing to say more.
    If someone here wish to help you... let be welcome!
    Regards!
  9. The Following 4 Users Say Thank You to bobolin4o For This Useful Post:
    aem (15th November, 2017), konq100 (15th November, 2017), nickolasd (15th November, 2017), pike (15th November, 2017)
