Results 1 to 12 of 12
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    Default Mercedes A-class W168 key generate
    please help with generate key for Mercedes A-class W168 - dump from 0D69J in attachment.
    star error in dash and the original key does not work key data original one attached two maybe someone like mr addick can help
    thanks in advance
    EU Romania
    Try to use some transponder programmer what you have !
    Upload you dump and add blank transponder what need and select writhe transponder for MB and need to work !
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    it will not work if not close the transponder properly i need config data construction and add manually the key please help and check for me if there is any keys know in that dump
    EU Romania
    I check you dump and you have inside 3 key stored !
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by MOHCIN2 View Post
    thanks in advance
    You need write to our friend adikk to get help from him.
    Minsk, Belarus
    Sorry of delay, only now I return to work.
    You have 3 used key (1-3), I send 1,4,7 keys. Try write 1 or 7 to new chip and config its as in .txt. And Your upload key very similar to key#4 !?! May be try check pass of 4-s key and rewrite key (If pass true - its possible. You dont can reset pass but can write new data).
  7. The Following 2 Users Say Thank You to adikk For This Useful Post:
    daxxer (10th September, 2017), lion0304 (10th September, 2017)
    Minsk, Belarus
    Key for dudul:
    You have 2 used key (1,2)
    write chip and config its as in .txt
  9. The Following User Says Thank You to adikk For This Useful Post:
    dudul (22nd November, 2017)
  10. #8
    Dec 2010
    Russia
    hi
    i need transponder data for this dump w168 1d69j,please
    regards
  11. #9
    dragoshu's Avatar
    Aug 2016
    Dacia
    Can Anybody check for me this dump ,it form mb slk 1d69j immo box,
    I remove immo box and dash and put it back and after that car never start. Any help will be appreciated.
    If I help you dont forget to push thanks button
  12. #10
    Hello!
    I have a mercedes W168 with lost keys. Can you help me to close the transponder? File is read with Xprog. I try to make transponder with Tango but doesn t work.
    Thank you!
  13. #11
    Minsk, Belarus
    Tango wary well work of its car (if You have keymaker) - not need any change in chip. May be You have other trable - not in key? What You see of diagnose?
    P.S. info about config PCF I send for You year ago
    P.P.S. But not have any answer
    P.P.P.S Mary Christmas!!!
  14. The Following User Says Thank You to adikk For This Useful Post:
    droidwayne65 (27th December, 2018)
  15. #12
    hi, this one is from another car. I solved the one before with what you had sent me.(Tango didn't help me in the past with this model) If you can send me the config for closing this transponder, I would very much appreciate! Thanks
