did make w204 AKL on bench with obd-eis adapter,take about 1h-1h.30m for collect data
p1et (24th August, 2019)
Here link for new update...
2.8.7.07...
emiliogsm (24th August, 2019)
link you listed for cgdi 2.8.7 is missing decryption key to download it.
Nymike (25th August, 2019)
https://mega.nz/#!Z4VEBS5J!kRE12VRvG...suV4BWV6yfNTUU
here a direct link....
wrong link in my other post...
didnt see an update list in here and just saw the latest one so heres the updates for 2019 so far
also their site is here and downloads are available..........
http://www.cgprogcar.com/en/?c=list&cs=xiazaizhongxin
CG-MB BenzMonster V2.8.7.0 NEW
(2019.08.23)
1. Added SLK (R171), C-Class (W204), CLK (W207), E (W212), GLK, SLS (197), CLS (W218) instrument EEPROM reading and writting function.
2. Fixed the problem of 1645450708 fast acquisition cannot calculate the password.
3. Added the new 21DF key reading function.
4. Added the 00032638 chip resetting function.
CG-MB BenzMonster V2.8.6.0
(2019.07.20)
1. Added the infrared read EIS function. (requires simulation key)
2. Optimized the without gateway all lost collection function for the old 164 EIS. (more stable)
3. Added the no gateway wiring diagram of old 164 EIS , modifyed the 204-204-212 lock wiring diagram.
4. Added the 21DF key write function. (Support the 57 key of the deputy factory on the market, support write the original key that VVDI erased)
5. Added the CG key reading identification code function.
6. Added the CG key switching key frequency function.
7. Added the CG key checking function.
8. Added the CG key point collection function.
9. Added the CG key point redemption function.
CG-MB BenzMonster V2.8.5.0
(2019.07.06)
1. Added all lost collection function for W215/W220 locks.
2. Changed the way of wiping the auto computer. (Solved the problem that parts of ECUs cannot clear)
3. Fixed an issue where calculating passwords might go wrong.
4. Changed the old version164,221 locks all lost collection process.
5. Added the K-line locks wipe and write function.
6. Added 220EIS/215EIS/210EIS/208EIS/203EIS/639EIS/906EIS direct replacing the locks through the infrared , The world's first release.
7. Added 220EIS/215EIS/210EIS/208EIS/203EIS/639EIS/906EIS direct clearing the KM number through the infrared , The world's first release.
8. Added Mercedes FBS4 key disable function, Supported models:205、222、166、447、246、218 etc.
9. Added the Spanish language display.
10. Added paypal payment function.
11. Replaced part of the wiring diagram.
12. Adjusted software interface layout.
13. Optimize network connection stability.
CG-MB BenzMonster V2.8.4.0
(2019.05.10)
1. Added device status check function before collecting data.
2. Added the all loss collection function of the EIS W639 (CAN 2009-).
3. Added the AC adapter fast collection function of the EIS W639 (CAN 2009-).
4. Fixed the problem that the new simulator is recognized as the old simulator when the connection is not normal.
5. Corrected the EIS W210 AC adapter fast collection wiring diagram.
6. Added W169 all loss collection wiring diagram,W639 (CAN 2009-) all loss collection wiring diagram,W639 (CAN 2009-) AC adapter fast collection wiring diagram.
7. Shielded the EIS K-line wipe function.
8. Shielded the EIS W204 AC adapter fast collection function.
9. We have added perimeter servers to improve the network connectivity experience for users outside China.
CG-MB BenzMonster V2.8.1.0
(2018.12.19)
1. Added K-line all lost collection support EIS Model
202/208/210, 203/463/639
2. Optimize the Keyless repeatedly plug collecting process
Fix problems that can cause program errors in specific situations in the collection.
3. Optimize network connectivity and improve server connectivity stability.
4. Software display language increases regional restrictions.
Devices sold in the China region can only use Simplified Chinese.
The thanks button is HERE looks like this --->>>
THANKS
whiskeyman (26th August, 2019)
today tested again after update, 1645450708 not working!
Newest update....
2.9.0.0
https://mega.nz/#!2aAm1KAS!gUj9r-4qv...E4Ate8HOhp9jz8
CG-MB BenzMonster V2.9.0.0 NEW
(2019.08.27)
1. The interface display language added French support.
2. The interface display language added German support.
THANKS
Jimalex (28th August, 2019)
Hello,can w203 2002 done by obd and if so what is the proccedure?
this is spare key
newone (28th August, 2019)
