Can i get erase password for w211 elv? Special key is: 8C A0 D4 E6 8C A0 D4 E6
ficho (6th September, 2019)
digital kaos did change theme style? from black to white?before was better...
barho67 (7th September, 2019)
also on very bottom right of every page
where it says default style change to dark core
The thanks button is HERE looks like this --->>>
THANKS
ficho (8th September, 2019)
i want to now with tool can do add key benz car with FBS4 Protocol
thanks in advance
"ß$¤ßłpúőpúßßłŁ$ßßłjáßßłßł$×÷łŁł¤ß=
Is there any known issue with HC908 based EZS(W203 for example) and BE keys? I tried VVDI keys v1.4, v1.5, noname keys and always I've the same problem. The faults are "B1025 The input signal 'circuit 15' is not o.k. " and "B1032 The input signal 'circuit 15R' is not o.k.". The symptoms are dead cluster, no horn, no wipers, no turn signal, etc. The engine is starting and running.
eliaselias (11th September, 2019)
sprinter 2012 AKL cgdi can make key on the car by obd? or must remove eis? are it difficalt to remove eis out?
