Page 107 of 172 FirstFirst ... 75797102103104105106107108109110111112117157 ... LastLast
Results 1,591 to 1,605 of 2576
  1. #1591
    Jun 2013
    On bench with good programer
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  2. #1592
    Aug 2013
    uk
    Need some help
    Vito w639 AKL on bench
    Never done on bench or AKL
    trying to read the instruction all over the net...
    Step 2: calculate pass
    CGDI MB calculated password
    NOT by OBD
    waiting to read EIS data
    pls unplug the direction lock ELV and connect the clip on the yellow line of the OBD line on the directional lock plug (the most fine line in the directional lock connector in the K-Line)
    collecting….
    What does the above mean..
    Take elv out connect on bench to power ,ground,and the yellow cable from obd cable to kline...???
    Im using AC Adapter for fast data but getting lost trying to follow it..
    Could some explain please.
    Many thanks
    If i helped.... please dont forget to press the THANKS + REP buttons .
  3. #1593
    Serbia
    You have wiring diagram in benz monster window... Instructions are for collecting data on car. ( unplug elv ) and connect clip on cgdi yellow cable mean that on car is (on elv plug) finest wire-K line. On bench you need to connect yellow wire of cgdi on eis k-line...
    http://blog.obdii365.com/2019/02/11/...all-keys-lost/
  4. The Following 4 Users Say Thank You to pletik For This Useful Post:
    Hayssam1 (14th September, 2019), Jimalex (14th September, 2019), taxo1965 (26th September, 2019), thayer201 (13th September, 2019)
  5. #1594
    Ecuprog31's Avatar
    Mar 2018
    W203 add key obd ok 10min
  6. #1595
    Serbia
    Have problem with w169. Car came to mechanic with unlocked elv but key cant turn . They tried to put other eis from another car and then elv locked. Than car came to me. Original eis is 169 545 11 08. They tried 169 545 15 08. These tvo eis are diffrent by number of connectors. 169 545 11 08 has 3 connectors and 169 545 15 08 has 2. I have reed orig eis with smok j-tag, made BE key with cgdi, tried with emulator on bench... not work... on car... not work. Then I wrote eeprom from ...11 08 to ... 15 08, made new key form 11 08 dump, tried on bench... works, tried on car... car starts. Probably wrong calculation for 169 545 11 08 with CGDI... also wrong calculation with SKC... Hardware difference between these two eis are in small connector with two twisted wires that 169 545 15 08 don't have. Without these wires, there is no communication with vehicle with star...
    I had same problem with w169 few months ago, but I had working key and I have made spare key. Also calculation did not work with cgdi and skc from dump. Solved with cgdi online pass calculation with working key.
    Solved. With SKC calc and original used key. BE key did not work on this EIS and CGDI did not calculate keys well. Maybe for someone will be helpful.
  7. The Following User Says Thank You to pletik For This Useful Post:
    electronicar (23rd September, 2019)
  8. #1596
    Apr 2019
    Quote Originally Posted by pletik View Post
    How you wrote eeprom from 11 08 to 15 08? First you must renew 15 08 or direct wrote eeprom?
  9. #1597
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    here the newest cgdi mercedes update...
    2.9.1.0.
    https://mega.nz/#!sSphCY5I!K0dNcUV5HfJuNSnhTXOH4og1UHJcMSJrVVfAlZS nQQE
  10. The Following 3 Users Say Thank You to figani For This Useful Post:
    Alexuko (17th September, 2019), barho67 (17th September, 2019), newone (17th September, 2019)
  11. #1598
    Serbia
    Wit programmer smok j-tag in circuit on bench.
  12. The Following User Says Thank You to pletik For This Useful Post:
    niksata90 (17th September, 2019)
  13. #1599
    Feb 2016
    Hello. I can not reset 567897081 chip. The other chip i can reset without any problems. Who try to reset 81 chip. Thanx.
    Отправлено с моего Redmi 3S через Tapatalk
  14. #1600
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by dusichek2012 View Post
    I have problems with resetting every NEC chip but finally after many attempts it will do. Last week I tried NEC 081 and it wasn't able to reset in multiple tries. Then I closed the software and re-open and it reset 1st time. Not sure if it's the solution or I was lucky but you can try that
  15. The Following User Says Thank You to p1et For This Useful Post:
    IchBins (21st September, 2019)
  16. #1601
    Quote Originally Posted by figani View Post
    2.9.1.0.
    Hi!
    What is this? (THERE is no file to download!)
  17. #1602
    Jan 2017
    USA ����
    CGDI MB V2.9.1.0 Released!!!
    CGDI MB Benz Monster V2.9.1.0 NEW (2019.09.17)
    The Mercedes monster calculates the password in only 24 seconds.
    50% of users only need 24 seconds to complete the calculation
    40% of users need 35 seconds complete the calculation
    10% of users need 70 seconds complete the calculation Quality Experience:
    1. Fix the 21DF key write function;
    ​​​​​​​solve the problem that other clear keys(the data inside the key can be used to rewrite after erasing the data) cannot be written.
    2. Optimize the reading key experience; (reading speed is greatly improved)
    3. Optimize the read lock experience; (read speed is greatly improved)
    4.Add the function that 164 (2009-) does not require a gateway to collect all lost.
    (Supports no gateway repeated plugging and AC fast acquisition)
    5. Add new 164 (2009-) no gateway full drop acquisition wiring diagram;
    6.Modify old 164 (2009-) no gateway full drop acquisition wiring diagram;
    7. Modify the W203/W463/W639K lock wiring diagram.
    2.9.1.0
    https://mega.nz/#F!iaZWxSKK!qUCFas1gnSK2EVAOgZGN0w
  18. The Following 3 Users Say Thank You to sleepyrz For This Useful Post:
    bocaje (22nd September, 2019), k1mlock (4th October, 2019), Nymike (22nd September, 2019)
  19. #1603
    Does the "Enable Key" function work? I follow all the required steps but I'm getting the error message you see in picture.
  20. #1604
    Quote Originally Posted by papalos_ View Post
    Hi!
    For newly programmed (added) Key , you do not need to enable it, just put in EZS one time for about 10 Seconds and remove + reinsert.
    It will be enabled automatically.....
    Regards,
  21. The Following User Says Thank You to Kaluluka For This Useful Post:
    papalos_ (26th September, 2019)
  22. #1605
    newone's Avatar
    Oct 2016
    Hello,had same problem when tried to enable customers missing key after finding it,got enable password ok then asked for the simulation key to be inserted in eis and then failure message,any ideas?
