Page 111 of 172 FirstFirst ... 1161101106107108109110111112113114115116121161 ... LastLast
Results 1,651 to 1,665 of 2578
  1. #1651
    Mar 2019
    Moldova
    Thank you.
  2. #1652
    Oct 2017
    just an update the w221 and w164 that's I was telling you guys about both AKL were done in less than 30 min with the AC adapter after EduardNN helped me out and taught me how to force the ignition open. process was smooth. I was hoping someone could tell me where I could find the key cutting codes for these vehicles? I have the lishi but I can't get it right
    Sent from my SM-N950U using Tapatalk
  3. #1653
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by esx503 View Post
    What do you mean by open ignition? You did this on car or what?
  4. #1654
    Oct 2017
    Quote Originally Posted by p1et View Post
    I did it on bench with the AC adapter and by open ignition I meant turn the ezs to the ON position. I never even knew you could/had to turn it to the on position in order to collect data.
  5. #1655
    rtvservis's Avatar
    i neda to svap transmision electronic on wdd207 . i menage to erase used tcu electronic . ho to activated that tcu to car bay cgdi . help pleas
  6. #1656
    hi!
    can someone cals erase password bcs server maintance now
    tnx
  7. #1657
    Please i need erase pass for w204 EZS .
    special key ; B6 6A B3 D8 5C DF F5 57
  8. #1658
    Aug 2010
    Quote Originally Posted by abdulrauf View Post
    Here is your Erase Pass:
    Jonny
  9. The Following 2 Users Say Thank You to jonny r For This Useful Post:
    abdulrauf (25th October, 2019), taxo1965 (26th October, 2019)
  10. #1659
    newone's Avatar
    Oct 2016
    Hello,can non keyless keys work in a keyless car,car will start with key in ignition?remote will work?
  11. #1660
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by newone View Post
    on keyless k-line car i can't collect data thru IR with cgdi i had to remove the EIS and dump it but after that the simple vvdi made BE key works fine. Remote too.
  12. The Following User Says Thank You to jodge For This Useful Post:
    newone (26th October, 2019)
  13. #1661
    Thank it work perfectly. THNKS
    Quote Originally Posted by jonny r View Post
    Jonny
  14. #1662
    Mar 2019
    Moldova
    Which keys are the best to use?
  15. #1663
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by tankist83 View Post
    Original NEC However if you ask between chinese BE keys there is no 1 simple answer. I ordered 10pcs CGDI MB keys but haven't tested yet.
  16. The Following User Says Thank You to p1et For This Useful Post:
    tankist83 (31st October, 2019)
  17. #1664
    Mar 2019
    Moldova
    Yes I mean BE key.
  18. #1665
    Sep 2017
    Toledo - Spain
    Hola a todos
    , tuve un problema con un EZS 203 545 03 08, y no puedo hacer nada con CGDI MB, tengo todas las teclas desactivadas y la clave, número 5, que es la que funcionó, todo a cero .
    No puedo eliminar EIS, ni escribir EIS, ni habilitar claves.
    Te dejo una foto para que puedas ver lo que me pasó.
    Alguien puede ayudarme?
    Lo estoy haciendo en el banco con el AC.
    Saludos
