Page 117 of 178 FirstFirst ... 1767107112113114115116117118119120121122127167 ... LastLast
Results 1,741 to 1,755 of 2659
  1. #1741
    Aug 2010
    Quote Originally Posted by kristikapa View Post
    Please find attached read from this ecu.
    Your Key Hashes are read out correct. These are real Key Hashes.
    Key0: F42B1402327C9374 -> 0X2FFFF = INITIAL: A83292637A934A99
    KEY1: 91499FDD03B7C396 -> 0X2FFFF = INITIAL: 30C873DA5039452D
    KEY2: E5D21D6D40D2D71E -> 0X2FFFF = INITIAL: C82645E1F3AA61B1
    KEY3: 9F824104720CE667 -> 0X2FFFF = INITIAL: 94E8C3D2B5D7F4F4
    KEY4: 71300B9F56F8958C -> 0X2FFFF = INITIAL: DEAAE151AB091708
    KEY5: 6E50AF370C6F13A8 -> 0X2FFFF = INITIAL: 8F956902D1111FB5
    KEY6: 9D21A8370CB13F46 -> 0X2FFFF = INITIAL: 00F49E889AFA43D3
    KEY7: 021BAC26C91A9750 -> 0X2FFFF = INITIAL: 5397F3EA1396ACCA
    I notice the TP Hash in your screenshot .... I assume this is ECU from some DAS2b system car ....
    If this is the case, then this explains why the dealer key does not comply. These DAS2b systems work different than FBS3.
    The ECU gets authorization via Hash, this explains why your Key Hashes are all valid, however, the renew procedure for such systems works different ....
    Tell me please, does this car have a Transponder Key with WFS ?
    If yes, then please read the 29F400BB from your SIM4LE ECU and upload dump here and i will make renew for you manually
    Jonny
  2. The Following 5 Users Say Thank You to jonny r For This Useful Post:
    alkazav (16th January, 2020), daxxer (16th December, 2019), glk96000 (20th January, 2020), jodge (17th December, 2019), kristikapa (16th December, 2019)
  3. #1742
    Top Poster kristikapa's Avatar
    Hello.
    Yes. You are right. Car is das 2b. Didn`t know renew procedure is different.
    Car has start error on dash and not cranking. I check real time data on wsp and is saying car is authorised to start but on ecu starting is not enabled.
    I read flash today and tried to renew using the attached file. After renew I did initial startup wih das, procedure completed succesfully but car still has start error on dash.
    Can you please check if my renewal file is ok?
    Also, I opened the key but didn`t see any coil for transponder reading. Do these cars have transponder inside the key, or the immobiliser is disabled when car receives unlock signal from remote?
  4. #1743
    Aug 2010
    Hello.
    Yes, i compared your Renew File with my file and it is OK.
    Yes, these W170 or R170 have a transponder inside Key
    Here are some pictures of W170 SLK Key with transponder inside
    On DAS actual values you should see if the Key is recognized by the WSP. Also, when you insert Key and try to start the car the Hash value inside your ECU should decrement by one. You can read again ECU Hash list and you should see Hash value for the used key track has changed (Same as with FBS3) If the Hash value is the same (not changed) then i assume the WSP has not sent a Hash to ECU, therefore i would check again communication between the Key and the WSP
    Jonny
  5. The Following 3 Users Say Thank You to jonny r For This Useful Post:
    alkazav (16th January, 2020), ficho (18th December, 2019), kristikapa (16th December, 2019)
  6. #1744
    OK. Makes sense now. I was expecting to see the transponder on board as in newer keys. My key doesn`t have the red cover where the transponder should be. I bet transponder is missing too. Thanks.
  7. The Following User Says Thank You to kristikapa For This Useful Post:
    jonny r (16th December, 2019)
  8. #1745
    Aug 2010
    You are welcome,
    Good Luck
    Jonny
  9. The Following User Says Thank You to jonny r For This Useful Post:
  10. #1746
    Dec 2016
    Azerbaycan Baku
    Hello
    where is the most profitable to buy CGDI Prog for MB ?
  11. #1747
    super jumbe's Avatar
    Livingstone
    VVDI Prog EZS Adapter for Benz EIS/EZS W164 W169 W203 W209 W211 W215 W639 10PCS.
    No need to solder wires just use socket to read data.
    1. Don’t need to solder.
    2. Read data perfectly.
  12. #1748
    what keys do you prefer to use? my experience with BE keys is not so great, key is very slow has big delay. I tried some other china NEC keys but not sure if key is bad or cgdi cannot support it? Doesn't even read the key
  13. The Following User Says Thank You to phatty123 For This Useful Post:
    bocaje (20th December, 2019)
  14. #1749
    scotland clydebank
    Can somebody tell me what models of mercedes sprinter keys cgdi mb do up to what year obd only please to add keys thank you .
  15. #1750
    Apr 2016
    if system is keyless, but i`am writing regular key, should i use 051 generated format?
    sometimes w164 with keyless system have problems with key synchronization
  16. #1751
    Feb 2016
    Quote Originally Posted by godfathertre View Post
    If your key is be or original, but not bga, and your system isn't fbs4 you can write keys. If system is fbs4 you can write only empty dealer key.
    Отправлено с моего Redmi 3S через Tapatalk
  17. #1752
    Anzelmas's Avatar
    Stockholm, Sweden
    Hi, m8s!
    Recently I have bought CGDI MB programmer. Now I am learning how to work with it. So, if my questions looks stupid, don't throw tomatoes, please.
    First question. Can I renew the original MB W164 2010 key? I can read it, but the "Reset" button is grayed.
    Second question. I want to change ISM on MB S320CDI 2006.05 If I reset the donor ISM, can I program it to the car with Star Diagnose or must I use some other adapter?
  18. #1753
    Anzelmas's Avatar
    Stockholm, Sweden
    I can answer to my second question by myself. CGDI reads, calculates the password and erases ISM in seconds. This work can be done on bench or by OBD. After ISM is erased you can learn it to the car with Star Diagnose without problems.
    The first question is still actual.
  19. #1754
    jodge's Avatar
    Mar 2017
    you got a little pcb too
    desolder the NEC from the key, solder into the little pcb check the label navigate to key menu choose from the list and do what you want...
    edit:
    if it's fbs3 ofc.
  20. #1755
    Quote Originally Posted by Anzelmas View Post
    I could not erase the ISM (continental) on the W164 installed on the car. Reading and calculating the erase password were successful, but the ISM was not erased. I had to remove the ISM from the car, connect it according to the scheme from the CGDI shell, and the erase was successful.
    For my bad English - scold GOOGLE translator...
    Don`t forget to use
    Thanks button and reputation
  21. The Following User Says Thank You to EduardNN For This Useful Post:
    niksata90 (26th December, 2019)
