Page 119 of 178 FirstFirst ... 1969109114115116117118119120121122123124129169 ... LastLast
Results 1,771 to 1,785 of 2659
  1. #1771
    mobinec's Avatar
    Jul 2011
    Take out terminal(+) from battery 10 min,after that put the key several times in eis and wait,i m have the same problem
  2. The Following User Says Thank You to mobinec For This Useful Post:
    fakir mohamed (5th March, 2024)
  3. #1772
    Jun 2017
    US
    S430 2003 spare. Got halfway through the data acquire then original key stopped turning eis and remote stopped working. Key was acting up beforehand though, that's why they wanted a spare, so not sure if cgdi messed up or if key just went dead again. Pulled module w220 to tried to read in circut with vvdi prog, but didn't see this 220 in the list, looked different on the layout and had different mask roms. Ended up reading original key eep, then writing to a China key, then it would read password. Calculated new key and eis turned but remote only made hazards blink only with unlock button and when the drivers door was open. Maybe should have better keys on hand or tried another slot but customer was happy with it as it was.
  4. The Following User Says Thank You to darknezz19 For This Useful Post:
  5. #1773
    Nov 2017
    Hello, i have bought an cgdi mb, and now i have an issue, can not calculate erase password on elv
    Can anyone help me?
    Special key 2D 96 AB AB 31 CF 48 64
  6. #1774
    newone's Avatar
    Oct 2016
    Hello and a happy new year,try to reset a nec key with 567897061 v40,it can read but reset always fails,any ideas?
  7. #1775
    rob h's Avatar
    May 2011
    Quote Originally Posted by darknezz19 View Post
    China Keys work well.
    Assuming that the MHz is correct.
    Load dump in skc tool,.might reveal faults in data.
    Partnumber and mask??!!
  8. The Following 2 Users Say Thank You to rob h For This Useful Post:
    darknezz19 (8th January, 2020), niksata90 (4th January, 2020)
  9. #1776
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by newone View Post
    I have this problem all the time when trying to reset NEC. Most of the times it will finally work but sometimes need to ty 30+ times...
  10. The Following 3 Users Say Thank You to p1et For This Useful Post:
    darknezz19 (8th January, 2020), djole3113 (8th January, 2020), newone (3rd January, 2020)
  11. #1777
    Quote Originally Posted by rob h View Post
    Which key do you use? I got some key from autokeys.us cgdi cannot even read them in IR and vvdi be key working but slow. on W220 insert key wait then turn the key with original key no issues
  12. #1778
    Jun 2017
    US
    I forget the mask but think both chips started with D1JXX. They were also on opposite sides of the PCB, not next to each other like on the ones listed in VVDI Prog. Prog listed the mask but needed adapter and had no hot air.
  13. #1779
    Jan 2017
    USA ����
    how are cgdi keys?
    they make their own be keys
    blurb from a seller
    1. Support all Mercedes Benz till FBS3
    2. Never lose synchronization
    3. Support Automatic Recovery
    4. Suitable for 208,203,215,210.220.211.209,164.221.216.166.169.63 9.204.207.212
    5. Applicable models: W221 W216 W164 W251 After Year 2009 Including: S Series, ML Series, GL Series and R Series.
    6. You can get 200 bonus points when use CGDI MB to program this key. 200 points= 1 token for CGDI MB (token valued $4 when you buy it alone).
    For the points, if you don't need to change for token, you can also exchange for other device on CGDI online store later.
    7. This is CGDI MB Be Key Update Version. Adding remote control lifting, window function and IR remote control.
  14. The Following User Says Thank You to sleepyrz For This Useful Post:
    taxo1965 (5th January, 2020)
  15. #1780
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by sleepyrz View Post
    you will say they copy other keys as well all other tools....
    but no any time can be stupid copy same as original
    many thanks to friend kevfield
  16. #1781
    Jan 2017
    USA ����
    Quote Originally Posted by daxxer View Post
    well if for no other reason then they give you cgdi credits when you use them.........
  17. #1782
    Dec 2016
    Azerbaycan Baku
    Quote Originally Posted by p1et View Post
    Hello , today I also tried to do this on the w211 table and without successfully I need to get a lot of effort?
  18. #1783
    Dec 2016
    Azerbaycan Baku
    how are cgdi keys?
    blurb from a seller
    Where is better to buy their keys?
  19. #1784
    Mar 2014
    Had one sucess with NEC reset, but when try to write key file, cgdi first reset nec than wrote it. Before and after that, reseting was impossible using just normal reset function. But, not a big deal, its easier and faster to use new key .
  20. #1785
    Jun 2016
    CGDI MB update: adds 2015 -2017 Benz FBS4 mileage adjustment.
    Features:
    1. via OBD
    2. Without can filter
    3. Safe and stable
    4. Without dismantling
    Workable Mercedes Benz car models:
    W205 2015-2017
    W222 2015-2017
    C190 2015-2017
    C217 2015-2017
    C253 2015-2017
    X253 2015-2017
    W447 2015-2017
