Page 121 of 178 FirstFirst ... 2171111116117118119120121122123124125126131171 ... LastLast
Results 1,801 to 1,815 of 2659
  1. #1801
    Oct 2017
    Quote Originally Posted by 111arm View Post
    I have successfully programmed elv simulator on W204, password calculation took less than 1 min. Did everything on the car through obd connector.
    which simulator did you use? xhorse or cgdi?
    Sent from my SM-N950U using Tapatalk
  2. #1802
    Oct 2017
    does anyone have a solid answer to this question.
    can you use an xhorse elv simulator with this tool?
    I probably didn't 3 hrs trying to get one working but it will not write the eis data it reads it on the main screen but it does not read it on the window that opens when you hit Simulator ELV it gives me an error read simulator elv failed I tried it with the one from mk3 as well and it does the same thing. Finally I came here and another user on this thread had the same question and was in the same predicament I'm in so he wrote the data from the old elv into the emulator and it worked for him and for me but it says it's not personalized so I'm assuming we're missing something.
    any input of similar experiences would be appreciated. thank you guys
  3. #1803
    Oct 2017
    Quote Originally Posted by VitalyR133 View Post
    Hi mates. I am thinking to buy CGDI MB, but can somebody tell me - can it get eraze pass for reset EIS? I need to swap EZS a16454500908 on W164 2006 (unfortunatelly it has NEC inside and i just cant copy it wiith vvdi prog )
    So can i make used EZS virgin and adapt it to this W164 with CGDI?
    I am reading the whole thread, but i am at 34 page now, so maybe there where such questions, but i need few days more to read.
    I've done about 5 of these cars I don't what chip was inside but I got password for it Everytime
  4. The Following User Says Thank You to esx503 For This Useful Post:
    VitalyR133 (15th January, 2020)
  5. #1804
    Jan 2018
    Got today CGDI, activated blue service with one free token, connected to OBD to the car and generated keys within 10 minutes (i have working key). Super!
    On the bench cant connect to EZS without gateway. I have AC adapter and tried to do as wiring diagramm show, but no luck.
    Conclution: W164 2006 A1645450908 works perfect on the car. Gateway is needed for connection on the bench.
    Reset original key without problem and wrote it through IR. Central locks works ok too.
  6. #1805
    Dec 2016
    Azerbaycan Baku
    please generate pass for ELV W211 C9 F0 85 3C C9 F0 85 3C
    tell friends where is the best buy chrome keys BE?
  7. #1806
    Jan 2018
    New test. W164 old. same number A1645450908 AKL, after connecting with AC adapter and choosing Without key collection i was asked to pull out and insert in simulation key more and more. It is just enough to turn simulation key as it could be turned and collection is going pretty fast. No need gateway to do AKL, but couldnt read it through OBD without gateway. So after collection - made a calculation wtithin 5 minuts, and i have key files for this EZS. This is my second success with CGDI.
  8. The Following User Says Thank You to VitalyR133 For This Useful Post:
    111arm (17th January, 2020)
  9. #1807
    Feb 2012
    Can someone get me erase pass for MB EIS W169 spec key CB CD 2F 6D 75 B2 D3 2A
  10. #1808
    Oct 2017
    I was gonna say. I've done it with AC adapter without gateway AKL no problem so I'm glad you figured it out
  11. #1809
    Feb 2012
    Quote Originally Posted by alkazav View Post
    nobody can't help?
  12. #1810
    Feb 2012
    Jonny help me. Thanks Jonny you are great man
  13. #1811
    Jan 2018
    Quote Originally Posted by esx503 View Post
    Yep, I do
    Its a little bit strange, that it is possible to do akl without gateway, but it's impossible just to read without it with existing key))
    Отправлено с моего SM-N975F через Tapatalk
  14. #1812
    Dec 2018
    I tried a MB B-Class W245 year 2010 and I could not open the "open file/write" button after I read the orginal remote with the button "read key/chip" in the "read/write key" menue. What did I do wrong?
    I made the key with Zedfull with the bin file, buts thats not what I want.
  15. #1813
    newone's Avatar
    Oct 2016
    when you are ready to write the new key you put it in press read and then activates the open file option
  16. The Following User Says Thank You to newone For This Useful Post:
    Alpaholic (17th January, 2020)
  17. #1814
    Dec 2018
    Yeah, I generated the key file, went to the "read/write key" menue, put the original working key in the cgdi, read it with the "read key/chip" button.... then nothing. Not allowed to open the "open file/write" button. No popup.
  18. #1815
    Jan 2018
    What do you want to do with original working key? I did reset first, with NEC adapter. Then put it to CGDI, read, and when you see that reader key is new and unused, only then write option become active. At yours screen you have used status. You can't do anything with it.
  19. The Following User Says Thank You to VitalyR133 For This Useful Post:
