Got it!!!! Had to turn the key in the cgmb :-)
Thanks Vitaly, but when I put the new be key inside and push "Read Key / Chip", there is a error message: "read the key information failed, please confirm the key has been inserted into the cgmb device or try again after cgmb power off!"
They send me a not working be key, that was the problem, damn store.
I've bought one CGDI BE Key, for check. When it will come i'll check how it works.
Besides got an update:
CG-MB BenzMonster V2.9.4.0 NEW
(2020.01.17)
1. Add the function of displaying and writing the key flag byte.
2. Add 2035450308 erase and write functions.
3. Fixed the problem that the smart 21DF key was successfully written and failed to display.
4. Add Turkish language display and Turkish language authorization function.
5. Other issues fixed and performance optimized.
6. You cannot use the device with the old software version, please install the latest software version.
Sorry, double post
Hello
please tell me where did you buy the keys?
don’t know they will add Russian?
You can buy the key here cg100procar or on Aliexpress
I think Russian will be added later. Today they added Turkish.
Got a customer today with an w164 ML 2011 without ELV. The customer key did not start the car or only if he put it 20 times in the eis. The cgdi reads the key without problems. so i think the problem must be the eis.
Is it possible to get the same eis on ebay and then copy by obd2 the old to the new?
no need to replace it. just disassemble it and see the problem.
Alpaholic (25th January, 2020)
Got 3 pcs cgdi mb keys. One reads normal, second sometimes read, very often not, third can be read once in 20 attempts. On the other side have couple aftermartket be keys(not cgdi) and those are very well.
Are there more Turkish-speaking users than Russian-speaking?
i can not make emulator for w204 esl, cgdi make dump and pass its ok but when i try to write dump to emulator(mk3) its says error check conection,but conection its 100% its can read emu but can not write, i did see video on youtube he make the same thing what i did with same emu,but for me its not working,i think its emu problem? https://www.youtube.com/watch?v=56UkDsPWs2k&t=2s
i have same problem
with ori cgdi emulator write is ok
with ori mk3
and china clone mk3
read write is not posible
barho67 (20th January, 2020)
