Page 125 of 178 FirstFirst ... 2575115120121122123124125126127128129130135175 ... LastLast
Results 1,861 to 1,875 of 2659
  1. #1861
    Jan 2019
    When I try to use the erase password with CGDI to erase 7G TCU I get error message that says erase failed. 2012 S63 AMG 722.931 Do I need to remove the TCU and do it on the bench and not in the car ?
  2. #1862
    Jan 2018
    Quote Originally Posted by wielandgeorg View Post
    I saw on YouTube ECU reset process with CGDI, there was fault to reset several times. And he just read, try to reset, read again. And after 6-7 time fault occured after read ECU was renewed. So maybe you should try to do it several times.
    I was reading 7g at Friday, got an erase password, but I didn't try to reset. Cause I have another job to do on it. But when I come back to work I will do what I need and try to reset TCU. I just need some time to get healthy.
    Отправлено с моего SM-N975F через Tapatalk
  3. #1863
    Top Poster kristikapa's Avatar
    You nned to connect in the gearbox plug not by obd
    Sometimes says failed to erase but if you read again you will see it's been done
  4. #1864
    Oct 2016
    France
    Quote Originally Posted by barho67 View Post
    i can not make emulator for w204 esl, cgdi make dump and pass its ok but when i try to write dump to emulator(mk3) its says error check conection,but conection its 100% its can read emu but can not write, i did see video on youtube he make the same thing what i did with same emu,but for me its not working,i think its emu problem? https://www.youtube.com/watch?v=56UkDsPWs2k&t=2s
    problem was not mk3 emulator,because i buy vvdi emu and cgdi say the same error : "write error" BUT it working,mk3 emu and vvdi emu start the car,o,lie cggi says error write but he did write it! now car start with booth emu)
  5. The Following 2 Users Say Thank You to barho67 For This Useful Post:
    igorr (8th February, 2020), nenadgorgi (28th January, 2020)
  6. #1865
    please help me with erase pass for 2 ecu reset . this is the special key - D7 5F F2 FD C0 57 41 B0 , 49 3B 94 9B 88 B1 B5 4F .
  7. #1866
    Aug 2010
    Quote Originally Posted by abdulrauf View Post
    It is interesting that your CGDI Tool has such poor results when trying to find Erase Pass ...
    Here are your 2 Erase Passwords:
    Jonny
  8. The Following 4 Users Say Thank You to jonny r For This Useful Post:
    abdulrauf (30th January, 2020), daxxer (5th February, 2020), ficho (2nd February, 2020), taxo1965 (2nd February, 2020)
  9. #1867
    Quote Originally Posted by jonny r View Post
    Jonny
    THANKS IT ALL WORK FINE.
  10. #1868
    Jan 2018
    TCU 722.9 reset ok. Did 2 TCU's: VGS2 and VGS3.
  11. #1869
    Mar 2016
    Hello Friends, what is:
    key flag byte ?
  12. #1870
    Dec 2016
    Azerbaycan Baku
    Hello Does anyone use these cables to work on the table?
    https://aliexpress.ru/item/330521949...c00NGsgaQ&mp=1
    can you know good advise please
  13. #1871
    Jun 2013
    Quote Originally Posted by ILHAM013 View Post
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  14. #1872
    Jan 2009
    Need to order cgdi mb, is it http://www.cgdishop.com ok?
    Tnx
  15. #1873
    Aug 2016
    who can tell me what this feature is for?
    Thks.
  16. #1874
    Feb 2016
    This feature activate your key, it will reduce key used times field for one point. Theoretically central locking on this key should work immediately, without insering the key into eis. But I'm not completely sure.
    Отправлено с моего Redmi 3S через Tapatalk
  17. The Following User Says Thank You to dusichek2012 For This Useful Post:
    chaoui05 (7th February, 2020)
  18. #1875
    Feb 2012
    yes, i bought from them
