Page 130 of 178 FirstFirst ... 3080120125126127128129130131132133134135140 ... LastLast
Results 1,936 to 1,950 of 2659
  1. #1936
    Mar 2018
    is that means CGMB not really calculate password and key files !?
  2. #1937
    Aug 2013
    Macedonia
    Please Cr3.11 erase pass calculation cgdi can not find pass
    Special Key - 92 EA 73 8C E2 61 01 CE
  3. #1938
    Quote Originally Posted by nenadgorgi View Post
    HI,
    Here is you request:
  4. The Following User Says Thank You to ficho For This Useful Post:
    nenadgorgi (17th March, 2020)
  5. #1939
    Aug 2013
    Macedonia
    Thanks Ficho all ok now i have problem to calc esl erase pass
    please pass for erase esl
    Special key - 92 EA 73 8C 92 EA 73 8C
  6. #1940
    This is a half hash (old esl type) that hash I provided should work on your esl, if not then use this hash A46AE1500F0D4A0D
    ficho
  7. The Following User Says Thank You to ficho For This Useful Post:
    nenadgorgi (18th March, 2020)
  8. #1941
    Aug 2013
    Macedonia
    i will try and report
  9. #1942
    Aug 2013
    Macedonia
    erase psw is ok thanks again ficho
  10. #1943
    witch one you used first one or second one ?
    regards ficho
  11. #1944
    Aug 2013
    Macedonia
    i use second one psw for esl
  12. #1945
    Nov 2010
    Default MB W211 program a new key in used position
    Guys,
    Last week I made a new key for my W211.
    Key number 1 &2 are used, but I do not have key 2 anymore...
    So I did write key file 2 to a new key and tried in the car but did not succeed. The display keeps telling me "Teach in new key please wait" for 10 minutes or so.
    Then I tried with key file 3 and that worked immediately.
    Any one knows why the key file 2 did not work?
    Is there any way to make it work in position 2?
    Don't get me wrong, I'm happy with my new BE key in position 3 but like to understand why position 2 did not work.
  13. #1946
    Quote Originally Posted by Msmax View Post
    Guys,
    1.read actual hashs from ezs
    2. calc key dump
    3. write key 2
    4. activate key
    5. should work
  14. The Following User Says Thank You to ficho For This Useful Post:
    Msmax (19th March, 2020)
  15. #1947
    Nov 2010
    Quote Originally Posted by ficho View Post
    2. calc key dump
    3. write key 2
    4. activate key
    5. should work
    Hi Ficho,
    That is what I did...
    1. Read EIS with CGDI MB
    2. upload & compute password
    3. Save file
    4. Upload & Generate key files
    5. Write BE key with key file 2...
    The display shows for a long time " Teach in key please wait".
    I removed the key after 10-15 minutes waiting and used key position 3 which worked immediately.
    Any step I missed?
  16. #1948
    Mar 2018
    Hi Ficho,
    3. Save file
    Any step I missed?
    I'm having similar problem as you~~
    is it CGMB not read and calculate hash correctly ?
  17. #1949
    Hi Ficho,
    3. Save file
    Any step I missed?
    Can You Activate the key with CGDI to be in state 14EC or 15EB
  18. The Following 2 Users Say Thank You to ficho For This Useful Post:
    Msmax (23rd March, 2020), sepistar (20th March, 2020)
  19. #1950
    Mar 2018
    Hi Ficho,
    3. Save file
    Any step I missed?
    You may try this:
    1. read EIS, paste the known key password, disable key slot2
    2. get enable password and enable key slot2
    3. insert working key(3) turn to pos2 ensure it is working
    4. read EIS, you will find the 'Special key' has changed.
    5. paste the known key password then save EIS data file
    6. (you can repeat from 1~6 two or three times)
    7. use the new EIS data file to generate key files
    8. write new key2 and try
    hope this help.
    If not, that mean key hash between EIS and ECU are mismatch and cannot sync,
    then you will need to read ECU key hash, wipe EIS, load EIS file, paste the ECU key hash then write EIS data...
  20. The Following User Says Thank You to babeh For This Useful Post:
